- From: Guillaume Brunerie <guillaume.brunerie AT gmail.com>
- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Functional context in tactics
- Date: Fri, 16 Dec 2011 03:25:20 +0100
2011/12/16 Adam Chlipala <adamc AT csail.mit.edu>
If you use [context] to find the subexpression you want to abstract, you can then run [pattern] on that subexpression, which will put the conclusion into precisely the form you want.Guillaume Brunerie wrote:
I want to write a tactic that should match the goal against something of the form [P (x + y)] where [P], [x] and [y] are arbitrary and [P] is bound to a function.
For example if the goal is something like [2 * (1 + 1) = 4] it should succeed and bind [x] and [y] to [1] and [P] to [fun t : nat => 2 * t = 4].
Is this possible?
I tried with second order pattern matching (@?P) but it does not work (I think this is because second order pattern matching only accepts variables as arguments), and I tried with [context], but I haven't found a way to build a function out of the context I get.
This seems to solve my problem, thanks :-)
- [Coq-Club] Functional context in tactics, Guillaume Brunerie
- Re: [Coq-Club] Functional context in tactics,
Adam Chlipala
- Re: [Coq-Club] Functional context in tactics, Guillaume Brunerie
Adam Chlipala
