- To: Wonchan Lee <wclee AT ropas.snu.ac.kr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] unfold definition on vectors
- Date: Mon, 19 Dec 2011 15:11:04 +0100
Le Mon, 19 Dec 2011 16:36:18 +0900,
Wonchan Lee
a écrit :
> Hello list,
> I'm curious about how to unfold definitions defined on vectors.
> Here is my code snippet and I got stucked at the last lemma:
> Inductive Vec (A : Set) : nat -> Set :=
> | Vec_Nil : Vec A O
> | Vec_Cons : forall n, A -> Vec A n -> Vec A (S n).
> Definition add (n : nat) (vec : Vec nat (S (S n))) : Vec nat (S n).
> Proof.
> inversion vec as [| n' x vec'].
> inversion vec' as [| n'' y vec''].
> apply (Vec_Cons _ _ (x + y) vec'').
> Qed.
> Lemma add_correct : forall (n : nat) (xs : Vec nat n) (x y : nat),
> add _ (Vec_Cons _ _ x (Vec_Cons _ _ y xs)) =
> Vec_Cons _ _ (x + y) xs.
> Proof.
> (* get stucked *)
> I wish I can unfold the definition of add in the proof, but it seems
> not allowed. Is there any tactic working on this case?
> Or, do I need a different approach?
> Best Regards,
> Wonchan Lee
That is normal since it is a proof ^^.
Just end "add" with "Defined" (I think "Saved." also works), so it
won't be considered a proof (or more precisely will be set transparent).
Take a look at what opaque/transparent is in the coq reference manual
for more informations.
- [Coq-Club] unfold definition on vectors, Wonchan Lee
- Re: [Coq-Club] unfold definition on vectors, AUGER Cédric
Adam Chlipala
AUGER Cédric
- Re: [Coq-Club] unfold definition on vectors, Adam Chlipala
AUGER Cédric
