coq-club - [Coq-Club] Semantics of simpl
chronological Thread
  • To: Coq-Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Semantics of simpl
  • Date: Mon, 19 Dec 2011 19:30:44 -0800
  • Importance: Normal
I am running into an issue in that the semantics of simpl change when it is executed alone or within the context of a composite goal.  Here is an abstraction of a portion of a proof derivation: (I am executing three steps, "eapply simplifyPre," "simplifyState," and "simpl" as three separate commands. (For anyone interested in analyzing this problem in more detail, I am more than happy to send complete source files)
______________________________________(1/4)
{{AbsExists AbsNat ...}}
{{?54140, NoResult}}
eapply simplifyPre.
simplifyState 0 (AbsExists ...)) ?74918
______________________________________(2/5)
{{?74918}}
simplifyState.
{{removeStateVar (AbsExists ...)}}
simpl.
{{AbsExists ...}}
Notice that in this first case above, that "removeStateVar" is evaluated by the simpl command.  It is a fixpoint function.  The first argument consisting of constructors of the form "Abs..." is a giant constant term. "removeStateVar" recursively traverses the term.
If instead of executing three separate commands, I combine them as follows:
    (eapply simplifyPre; [simplifyState|simpl]).
The resulting goal is:
The "removeStateVar" function is not evaluated.  It appears that the behavior of simpl is changing.  What is causing this change?  Is there a way to cause "removeStateVar" to be evaluated in the latter case?
                           - Ken
