coq-club - Re: [Coq-Club] typeclass methods in hints
chronological Thread
  • To: Tom Prince <tom.prince AT ualberta.net>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] typeclass methods in hints
  • Date: Fri, 23 Dec 2011 10:53:28 -0800
On Tue, Dec 13, 2011 at 17:44, Tom Prince
 wrote:
>> Is it possible to declare a typeclass method as a hint?  When I say
>> Hint Resolve some_method.
>> if no instances have yet been declared, I get a "cannot infer implicit
>> parameter" error.  If some instances have been declared, then
>> apparently only the method applied to the first such instance is
>> declared as a hint.  I can specify which instance I want with
>> Hint Resolve (@some_method some_instance).
>> but I want the hint to apply to *all* instances.  However, if I write
>> Hint Resolve @some_method.
> You probably want to add ': typeclass_instances' here.
Why?
>> I am told "some_method cannot be used as a hint".  Is there a way to
>> do this?
> Is is that some_method cannot be used as a hint by *auto*?
I'm not sure -- are you asking me?  This shouldn't cause the "Hint
Resolve" command to fail, should it?  The manual says that if a hint
will only be used by eauto, then "Hint Resolve" just prints a warning.
> There are a number of other things one can do. The simplest method is to use
> ':>' instead of ':' when declaring the projection ... this automatically
> declares a hint for the projection.
The method in question isn't a projection declared as part of the
typeclass definition, but a function defined later which happens to
take an argument belonging to a typeclass.  (Is the word "method"
wrong in this context?)
> You can also add arbitrary tactics as hints like
> Hint Extern 4 (<some-optional-patern>) => <some-tactic> :
> typeclass_instances.
Hmm, I'll try that.  Thanks!
Mike
