- To: Chris Dams <chris.dams.nl AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using sigT and existT
- Date: Thu, 29 Dec 2011 16:18:48 +0200
Thank you Chris and Adam! At least it is good to know that the lemma is (more or less) true. On 29/12/2011 16:11, Chris Dams wrote: Hello Ramon, Yes, especially the inversion tactic sometimes tends to produce the need to prove that kind of thing. I generally use the following lemmas for it. Not sure if it is the best one can get. Maybe somebody else has something better. Note that I only have been able to prove this lemma for types in which equality is decidable. Good luck! Chris Require Import Eqdep_dec. Definition sigT_get_proof: forall T: Type, forall eq_dec_T: forall t t': T, {t = t'} + {~ t = t'}, forall P: T -> Type, forall t: T, P t -> sigT P -> P t. intros T eq_dec_T P t H1 H2. destruct H2 as [t' H2]. destruct (eq_dec_T t t') as [H3|H3]. rewrite H3. exact H2. exact H1. Defined. Theorem sigT_get_proof_existT_same: forall T: Type, forall eq_dec_T: forall t t': T, {t = t'} + {~ t = t'}, forall P: T -> Type, forall t: T, forall H1 H2: P t, sigT_get_proof T eq_dec_T P t H1 (existT P t H2) = H2. Proof. intros T eq_dec_T P t H1 H2. unfold sigT_get_proof. destruct (eq_dec_T t t) as [H3|H3]. unfold eq_rect_r. symmetry. exact (eq_rect_eq_dec eq_dec_T (fun t: T => P t) H2 (sym_eq H3)). tauto. Qed. Theorem existT_injective: forall T, (forall t1 t2: T, { t1 = t2 } + { t1 <> t2 }) -> forall P: T -> Type, forall t: T, forall pt1 pt2: P t, existT P t pt1 = existT P t pt2 -> pt1 = pt2. Proof. intros T T_dec P t pt1 pt2 H1. pose (H2 := f_equal (sigT_get_proof T T_dec P t pt1) H1). repeat rewrite sigT_get_proof_existT_same in H2. assumption. Qed. |
- [Coq-Club] Using sigT and existT, Ramon
- Re: [Coq-Club] Using sigT and existT, Adam Chlipala
Chris Dams
- Re: [Coq-Club] Using sigT and existT, Ramon Snir
