coq-club - Re: [Coq-Club] Strange error on trivial unification
chronological Thread
  • To: Thomas Braibant <thomas.braibant AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Strange error on trivial unification
  • Date: Wed, 18 Jan 2012 13:30:02 +0100
Yes that showed it, thanks a lot! It was an issue with coercions.
Lu
On Wed, Jan 18 2012 at 13:23 +0100, Thomas Braibant wrote:
> You should enable the printing of implicit arguments with Set Printing
> All. This is a rule of thumb in this kind of situation, as it usually
> makes it possible to spot why two terms that appear identical are in
> fact different.
> With best regards,
> thomas
> On Wed, Jan 18, 2012 at 1:13 PM, Luminous Fennell
> <mstrlu AT gmx.net>
>  wrote:
>> Hi,
>> At some point in a proof I get this error:
>> Toplevel input, characters 21-90:
>> Error: Impossible to unify
>>  "has_type
>>    (concat empty
>>       (single x (t_arr sec_low (t_unit tsa_dyn) (t_unit sec_high))))
>>    (exp_unit tsa_dyn) (t_unit tsa_dyn)" with
>>  "has_type
>>    (concat empty
>>    (exp_unit tsa_dyn) (t_unit tsa_dyn)".
>> This seems strange, as the two expressions are identical. I suppose it's
>> a beginner's mistake, but how could this possibly not work? I would very
>> much appreciate any suggestions.
>> I'm using coq 8.3pl2-3 and ProofGeneral 4.1-1.
>> Thanks and best regards
>> Lu
