- To: AUGER C�dric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Positivity and Elimination Principle
- Date: Fri, 20 Jan 2012 08:39:15 -0500
AUGER Cédric wrote:
Consider the following "inductive".
Inductive p : Prop -> Prop :=
| P0 : p True
| P1 : forall a b, (p a \/ p b) -> p (a\/b)
| P2 : forall a b, (forall Q, ((p a) -> Q) ->
((p b) -> Q) ->
Q) ->
p (a\/b)
(It won't compile for positivity reasons)
For me, either P1 and P2 should be both accepted, or they should be
both refused, since P2 use the elimination principle of \/.
In fact P1 is accepted, but not P2.
I would be very surprised to learn that P2 is trully "unsound" whereas
P1 is "sound". Is there some particular reasons not to be compatible
with an elimination principle?
A key fact here is that [\/] is desugared to a use of another inductive family [or], while [->] is a built-in operation associated with the positivity condition. Your definition of [p] makes it a _nested_ inductive type, where, in the definition of [p], you refer to family [or] with at least one occurrence of [p] in its parameters. Here the checking rule is to make a specialized copy of [or] and consider it declared as mutually inductive with [p]. At that point, you apply the normal rules, where it is easy to see that omitting constructor [P2] gives a strictly positive definition.
In contrast, [P2] clearly violates the positivity rule. I'm not sure what is your basis for deciding that [P2] can't break consistency, but it's far from obvious to me. It's easy to see how allowing non-strictly-positive occurrences can break consistency for considerably simpler examples; I give such an example somewhere in CPDT.
- [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
- Re: [Coq-Club] Positivity and Elimination Principle, Adam Chlipala
Chung-Kil Hur
Adam Chlipala
- Re: [Coq-Club] Positivity and Elimination Principle, Chung-Kil Hur
- Re: [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
Adam Chlipala
Jean-Francois Monin
AUGER Cédric
Adam Chlipala
Andreas Abel
Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, Daniel Schepler
Dan Doel
Andreas Abel
Adam Chlipala
AUGER Cédric
Chung-Kil Hur
