coq-club - Re: [Coq-Club] Issue trying to define a match-like notation
chronological Thread
  • To: coq-club AT inria.fr
  • Cc: AUGER Cédric <Cedric.Auger AT lri.fr>
  • Subject: Re: [Coq-Club] Issue trying to define a match-like notation
  • Date: Fri, 20 Jan 2012 10:40:50 -0800
On Friday, January 20, 2012 03:02:30 AM AUGER Cédric wrote:
> By the way, I remember that some months (year?) ago, you said that
> you never had problems with the "inversion" tactic. Did you changed
> your mind, or do you just want to write terms to compute without using
> the tactic system?
I still don't have problems with using "inversion" -- but I do have problems
with using tactics to construct data parts of definitions.  (Although, these
definitions came out of some experiments I've been doing lately, to see how
to
unfold the results of the inversion tactic to eliminate the intermediate
equality propositions.)  Plus, if I try using "dependent inversion" to
outline
the skeleton before writing it out in full, that sometimes generates
intermediate JMeq statements.  And I think sometimes it uses the JMeq_eq
axiom
internally -- and that can destroy the possibility of directly computing
using
the resulting definitions.  I get similar problems if I try using the Program
system to write a definition without all the type casts and let it generate
type casts and equality obligations.
Overall, the resulting term involving vectorS_inv isn't *that* ugly, so I
think I'd rather put up with that than write 2^n notation declarations, or
use
what you suggested.  On the other hand, it could be nice to define one
alternative notation to allow me to drop "as _".
So I guess my previous message stated things a bit backwards: in fact, I had
the desire to write vectorS_match expressions, and have a back end which
would
easily simplify when applied to a vector_cons expression.  A plus would be to
have the expressions have nice Ocaml extractions (i.e. having "assert false"
in the invalid cases, rather than some expression involving Obj.magic).  I
already had a vectorS_inv function satisfying the first criterion some time
ago, and I think I may have already posted that version.  It was only
yesterday that I had an inspiration on how to refine it to satisfy the second
criterion as well.
In case you're interested, and you can't read the mess of vectorS_inv which
involves several "convoys" of P and Pcons through matches, the basic idea was:
Definition vector_tl {X:Type} {n:nat} (v:vector X (S n)) : vector X n :=
match v in (vector _ m) return
  (match m with
  | 0 => unit
  | S m' => vector X m'
  end) with
| vector_nil => tt
| vector_cons _ _ t => t
end.
This satisfies the first criterion but not the second.  (The Vector_nil case
extracts to "Obj.magic ()".)
To make the extraction nicer, rewrite instead:
  (match m return Prop with
  | 0 => False
  | S _ => True
  end ->
  match m return Type with
  | 0 => Empty_set
  end) with
| vector_nil => False_rect Empty_set
| vector_cons _ _ t => fun _:True => t
end I.
So, we provide a context Prop which in the correct case reduces to True, and
is ignored.  But in the incorrect case, it reduces to False, allowing us to
"raise an exception" instead of returning a garbage value.  Then in the
extraction, that context Prop is eliminated; and since the incorrect case
extracts to "assert false", I guess somehow the extraction process realizes
that the different return type of empty_set vs. 'a1 vector doesn't matter, so
no Obj.magic is needed.
Daniel Schepler
