- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: Dan Doel <dan.doel AT gmail.com>, coq-club AT inria.fr, Andreas Abel <andreas.abel AT ifi.lmu.de>, Adam Chlipala <adamc AT csail.mit.edu>, AUGER Cédric <Cedric.Auger AT lri.fr>
- Subject: Re: [Coq-Club] Positivity and Elimination Principle
- Date: Sat, 21 Jan 2012 12:13:25 +0100
Le Fri, 20 Jan 2012 13:55:22 -0800,
Daniel Schepler
a écrit :
> Actually, I guess that also gives an example of a positive, but not
> strictly positive, inductive definition which would lead to a
> contradiction:
> Inductive X : Type :=
> | X_const : ((X->Prop)->Prop) -> X.
> If Coq allowed that definition, then X_const, being a constructor,
> would automatically be injective, leading to the contradiction from
> my previous message. (Plus, I'm not at all sure what X_rect or X_ind
> would look like in that case.)
I was able to do your proof (I don't examine the following mail you
wrote, but I guess it is pretty much the same proof).
But I still think that positivity may be relaxed to allow replacement
with elimination principle of inductive types. I think these
elimination principle have some particular patterns; so maybe that
rules like:
| <Constructor_name> :
(forall (T:X -> Type), (forall u11..u1n, Y1 -> T (f1 u11..u1n)) -> ..
-> (forall um1..umn, Ym -> T (fm um1..umn)) ->
forall x, T x)
-> <Inductive_type>
could be allowed, where <Inductive_type> may appear positively (not
necessarily strictly). I am not sure it would be that useful, so it was
the aim of my first question.
Is what I said too complex to formalize and not enough useful to be
implemented?
Is there some case where putting an elimination principle instead of
the inductive can lead to inconsistency?
Axiom X : Type.
Axiom X_const : ((X->Prop)->Prop) -> X.
Axiom X_rect : forall (T:X->Type), (forall f:(X->Prop)->Prop, T
(X_const f)) -> forall x, T x.
(*What I would expect for the record*)
Axiom X_const_inj : forall f (P:X->Prop) (Q:((X->Prop)->Prop)->Prop),
forall f', (P (X_const f) -> P (X_const f')) ->
Q f -> Q f'.
Lemma X_const_injective: forall f1 f2, X_const f1 = X_const f2 -> f1 =
f2. Proof.
intros.
eapply X_const_inj; intros.
eexact H.
esplit.
Qed.
Lemma eq_inj: forall T (x y:T), eq x = eq y -> x = y.
Proof.
intros.
rewrite H.
split.
Qed.
Goal False.
set (g := fun h => X_const (eq h)).
assert (forall h i, g h = g i -> h = i).
subst g; simpl.
intros.
generalize (X_const_injective _ _ H); clear H.
apply eq_inj.
set (S0 := fun (x:X) => exists S, g S = x /\ ~ (S x)).
assert (S0 (g S0) -> False).
intros L.
assert (M := L).
destruct M as [S [K1 K2]].
assert (Heq := H _ _ K1); clear K1.
subst; auto.
apply H0.
exists S0; auto.
Qed.
- Re: [Coq-Club] Positivity and Elimination Principle, (continued)
- Re: [Coq-Club] Positivity and Elimination Principle, Daniel Schepler
- Re: [Coq-Club] Positivity and Elimination Principle, Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, roconnor
- Re: [Coq-Club] Positivity and Elimination Principle, Andreas Abel
- Re: [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
- Message not available
