coq-club - Re: [Coq-Club] examples of singleton elimination
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] examples of singleton elimination
  • Date: Thu, 26 Jan 2012 20:00:18 +0100
On 01/24/2012 09:41 PM, Hugo Herbelin wrote:
Hi,
You basically exhausted the elementary bricks of types for which
singleton elimination is allowed:
recursivity: Acc
tuples: True, and
indices: eq
emptyness: False
Indeed, indices is where finer discriminating criteria can be thought of.
I don't have much to add to what Hugo said. Just a couple of remarks:
- False_rect transports inconsistencies from Prop to Type: any proposition is inhabited implies any type is inhabited.
- singleton elimination for Acc can be viewed as the composition of the singleton elimination on tuples (Acc is a 1-tuple), with the possibility to write fixpoints with co-domain in Type, and recursive argument in Prop. The first part is harmless, but the second one implies False_rect: if we assume False, eq is a well-founded order, and we can inhabit any type with a well-founded recursion:
Check (fun (abs:False) (X:Type) =>
  (fix F (h:Acc eq 0) :X := F (Acc_inv h (eq_refl 0)))
    (False_ind _ abs)).
: False -> forall X : Type, X
Probably no reason to be worried in a homotopical world, though...
Bruno.
Bruno Barras                    Typical team - INRIA Saclay
LIX - Ecole Polytechnique       91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57          Fax: +33 1 69 33 30 14
