coq-club - Re: [Coq-Club] Installation Problem
chronological Thread
  • To: Jelle Herold <jelle AT defekt.nl>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Installation Problem
  • Date: Wed, 8 Feb 2012 08:04:15 +0900
Dear Jelle,
You gave me a wonderful solution. It works!
My problem seems to be caused by incorrect coq-prot-* settings. After applying .dir-locals.el as you suggested, I now see Coq/Emacs/ProofGeneral working well as I expect.
Thanks!!!
Kwanghoon
On Wed, Feb 8, 2012 at 7:37 AM, Jelle Herold <jelle AT defekt.nl> wrote:
On 02/07/2012 12:57 AM, lazyswamp AT gmail.com wrote:
Hi,
I have an installation problem. When I load a Coq script (.v) and start
navigating by pressing C-c C-n (Next), the Emacs editor seems to hang for ever
by giving a message:
     Starting coqtop -emacs-U
I am not entirely sure, but I think this is due to incorrect coq-prog-* settings. Currently my preferred way of running coq is by placing a file named ".dir-locals.el" in the parent folder of my coq project. The file contains:
((coq-mode . (
(coq-prog-args . ("-emacs-U"))
(coq-prog-name . "/home/wires/opt/coq/coq-8.4beta/bin/coqtop")
(Note the full path to the coq binary)
My .emacs file has no further settings.
Should you need to include libraries, then the format is
((coq-mode . (
(coq-prog-args . ("-emacs-U" "-R" "lib/something" "Something" "-R" "lib/else" "Else"))
I realize this is not an answer to your question but it might help...
Bye,
Jelle.
