coq-club - Re: [Coq-Club] Extraction of existentially quantified variables
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Extraction of existentially quantified variables
  • Date: Tue, 14 Feb 2012 18:17:43 +0100
On 02/14/2012 05:23 PM, Andrej Bauer wrote:
The extraction currently in Coq does not use a typed realizability model.
Thank you for the explanation. I simply assumed that the extraction
carries the types along. It seems harder to reconstruct the types once
they're thrown away.
It would be interesting to know if one can do "better" by following
more closely an interpretation of types as well as terms.
I'm not saying that all this could not be related to your way of
presenting extraction, but I don't consider your way the "primary" one,
as you seem to assert.
Untyped realizability is a special case of typed realizability (it is
the uni-typed case).
As far as I can tell, modified realizability has the property that the termination of realizers is known "a priori": originally, they were simply-typed lambda-terms. The point is that you can use the realizer outside its specification (but within its domain type!) without losing termination or type-safety.
In Coq, you could prove correct a division algorithm which extracted term loops when the divisor is 0. This is related to the difficulty to remove __ that Stéphane mentioned. In general, the trouble comes in when using singleton elimination or fixpoints with informative codomain and non-informative recursive argument.
Bruno.
Bruno Barras                    Typical team - INRIA Saclay
LIX - Ecole Polytechnique       91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57          Fax: +33 1 69 33 30 14
