- From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>, gmalecha AT cs.harvard.edu
- Subject: Re: [Coq-Club] Ltac unify expressions
- Date: Sun, 19 Feb 2012 17:03:20 -0500
- Authentication-results: mr.google.com; spf=pass (google.com: domain of gmalecha AT eecs.harvard.edu designates 10.60.3.167 as permitted sender) smtp.mail=gmalecha AT eecs.harvard.edu
This is great. Thanks.
On Fri, Feb 17, 2012 at 7:49 PM, Matthieu Sozeau <matthieu.sozeau AT gmail.com> wrote:
Hi Gregory,
there is an undocumented tactic [unify x y [with hintdb]] that
does exactly what you expect. And it's now documented in the
reference manual.
-- Matthieu
Le 17 févr. 2012 à 23:49, Adam Chlipala a écrit :
> OK, perhaps then this to avoid adding unused cruft to proof terms:
> (let unused := (refl_equal _ : a = b) in k true) || k false
> As for avoiding CPS, nothing comes to mind yet.
> On 02/17/2012 05:45 PM, Gregory Malecha wrote:
>> Does the [clear] call remove all traces of this from the proof? I'm going to end up calling this a lot (at least 100) and I'm worried about even small bits being left in the proof.
>> The other thing is that this means is that I have to cps convert all of my ltac. Is there any other way to do this? I assume there is some Ocaml function that I could expose using a plugin if this doesn't exist right now. Would this be reasonable?
>> Thanks.
>> On Fri, Feb 17, 2012 at 5:26 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
>> On 02/17/2012 04:44 PM, Gregory Malecha wrote:
>>> I am wondering if there is a better way to perform semantic equivalence checking in Ltac. Currently, I'm doing the following:
>>> Ltac unifies a b :=
>>> match a with
>>> | b => true
>>> | _ =>
>>> let a := eval cbv in a in
>>> let b := eval cbv in b in
>>> match a with
>>> | b => true
>>> | _ => false
>>> end
>>> end.
>> Here's one of those Gallina/Ltac puns that is both horrifying and super-fun IMO:
>> (let H := fresh in assert (H : a = b) by reflexivity; clear H; (* call a continuation with [true]) || (* call continuation with [false] *)
>> This may have side effects if there are unification variables left undetermined beforehand.
gregory malecha
- [Coq-Club] Ltac unify expressions, Gregory Malecha
- Re: [Coq-Club] Ltac unify expressions,
Adam Chlipala
Gregory Malecha
Adam Chlipala
Matthieu Sozeau
- Re: [Coq-Club] Ltac unify expressions, Gregory Malecha
Matthieu Sozeau
Adam Chlipala
Gregory Malecha
Adam Chlipala
