- From: Fr�d�ric Besson <frederic.besson AT inria.fr>
- To: "Jael E. Kriener" <jek26 AT kent.ac.uk>
- Cc: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] RE: question about evaluating a complex fixpoint
- Date: Tue, 21 Feb 2012 10:35:48 +0100
Hello Jael,
For your Fpd function, which argument do you wish to recurse on ?
As you did not write {struct ...} annotation, Coq infers {struct prog}.
If I write {struct a} instead, the definition is also accepted but the
computational behaviour is not the same -- simpl works.
(Sometimes, it can be useful to define the "same" function with different
{struct x} annotations and prove their equivalence.)
Best,
Frédéric
On 21 févr. 2012, at 10:20, Jael E. Kriener wrote:
> Thanks for the quick reply, Adam!
> I attached the wrong file the second time around - I'm very sorry! This one
> is self-contained and useful. Sorry again.
> Is it possible that using 8.4beta might make this trivial?
> Jael
> On 20/02/12 20:26, Adam Chlipala wrote:
>> On 02/20/2012 12:52 PM, J.E.Kriener wrote:
>>> I've defined a function over (dependent) types using Fixpoint and refine.
>>> Now I'm trying to prove something about it. So I'm trying to apply it to
>>> some specific arguments and look at the result. But I seem to be unable
>>> to simply do that:
>>> 'simpl' won't change a thing,
>>> neither will 'unfold ; simpl'.
>> [simpl] seems to do everything I expect in your simplified example. What
>> about the behavior surprises you?
>> Your example is odd, in that you use [Fixpoint] to define a non-recursive
>> function. Keep in mind that applications of recursive functions can only
>> simplify when the top-level structure of the recursive argument is known.
>> Perhaps an annotation to indicate which argument is recursive would help
>> you somewhere.
>> But I would just use [Definition] instead of [Fixpoint], in any case.
>> P.S.: The example still imports CoLoR modules, though it doesn't use them
>> later.
> <compute-problem.v>
- [Coq-Club] question about evaluating a complex fixpoint, J.E.Kriener
- [Coq-Club] RE: question about evaluating a complex fixpoint,
J.E.Kriener
- Re: [Coq-Club] RE: question about evaluating a complex fixpoint,
Adam Chlipala
Jael E. Kriener
- Re: [Coq-Club] RE: question about evaluating a complex fixpoint, Frédéric Besson
- Re: [Coq-Club] RE: question about evaluating a complex fixpoint, Jonas Oberhauser
Jael E. Kriener
Adam Chlipala
J.E.Kriener
