- From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Qed and Universes
- Date: Fri, 24 Feb 2012 15:39:27 -0500
- Authentication-results: mr.google.com; spf=pass (google.com: domain of gmalecha AT eecs.harvard.edu designates 10.182.1.104 as permitted sender) smtp.mail=gmalecha AT eecs.harvard.edu
Hello,
Is it possible for [Qed] to generate additional universe constraints? I'm working on a proof like this:
Theorem ...
Proof.
tactic.
Set Printing Universes.
Print Universes "universes".
Qed.
The final [Qed] fails, but when I look at the dump of the constraints in the universes file (the file can be found at: http://www.people.fas.harvard.edu/~gmalecha/universes), there is nothing inconsistent about them (I checked this using the yices smt solver). If it is possible for [Qed] to generate new constraints, is there any way to get the constraint set after it generates them so that I can find the cycle? (I'm experiencing this issue in 8.3pl2)
- [Coq-Club] Qed and Universes, Gregory Malecha
- Re: [Coq-Club] Qed and Universes,
Jonas Oberhauser
- Re: [Coq-Club] Qed and Universes, Gregory Malecha
- Re: [Coq-Club] Qed and Universes, Stéphane Glondu
Jonas Oberhauser
