- From: Thomas Dinsdale-Young <td202 AT doc.ic.ac.uk>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question on Opaque/Transparent and commands versus tactics
- Date: Mon, 27 Feb 2012 15:58:16 +0000
It's a bit of a hack, but something like the opaque tactic you describe may be implemented in Ltac as:
Ltac opaque_in id t := let y := fresh in let H := fresh in
(* introduce y for id *)
set (y := id); assert (H: y = id) by reflexivity;
(* forget about the definition of y *)
generalize dependent y; intros y H;
(* do t *)
t;
(* substitute back y *)
rewrite H in *; clear y H.
Something like "opaque_in x simpl" would prevent simpl from seeing the definition of x by substituting it for y.
In a related note, I'd quite like to see a tactic along the lines of "hide H in t" which runs tactic t without letting it make use of hypothesis H (and any hypotheses in which H occurs, providing H does not occur in the goal).
-- Thomas
On 24/02/2012 21:29, Francois Pottier wrote:
Dear all,
I find that, in some cases, it is necessary (or at least useful) to use the
commands Opaque and Transparent in order to control the amount of
simplification performed by the tactic "simpl". If "simpl" is too
aggressive, making certain definitions opaque helps.
This technique could be really useful if Opaque and Transparent were
tactics, as opposed to commands. This would allow them to be used as
building blocks in the construction of more complex tactics.
Have the Coq implementors given some thought to this idea? One might
imagine extending Ltac with tactics of the form "opaque foo in t" and
"transparent foo in t", where "t" is a tactic and "foo" is an identifier.
This would have the effect of changing the status of "foo" while "t" is
executed, and restoring it upon exit.
- [Coq-Club] Question on Opaque/Transparent and commands versus tactics, Francois Pottier
- Re: [Coq-Club] Question on Opaque/Transparent and commands versus tactics, Pierre Boutillier
- Message not available
- Re: [Coq-Club] Question on Opaque/Transparent... or: one step of reduction of a fixpoint,
Francois Pottier
- Re: [Coq-Club] Question on Opaque/Transparent... or: one step of reduction of a fixpoint, Stéphane Glondu
Francois Pottier
- Re: [Coq-Club] Question on Opaque/Transparent and commands versus tactics, Thomas Dinsdale-Young
