- From: Florian Lorenzen <florian.lorenzen AT tu-berlin.de>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Strange problem with `destruct' tactic
- Date: Mon, 27 Feb 2012 23:11:14 +0100
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dear all,
I have a very strange problem with the destruct tactic in Coq 8.3pl2.
I have the following proof context (I disabled printing of notations):
Γ : ctx
t0 : Tm
e1 : Emscp
H : Genrscp Γ (Emscp_cons t0 e1) Ty_nat
t' : Tm
H0 : Evr (Tm_scp (Emscp_cons t0 e1)) t'
e10 : Emscp
t : gdscp
t1 : td
Heqo : eq (tdof t0 empty) (Some t1)
H2 : eq
match
gdscpof (open_scp O (cons (Tm_fvar (freshvar S.empty)) nil) e1)
(cons (pair (freshvar S.empty) Ty_nat) empty)
with
| Some der2 =>
Some
(gdscp_cons t1 (freshvar S.empty) S.empty der2 empty
(Emscp_cons t0 e1) Ty_nat)
| None => None
end (Some t)
H1 : eq e10 (Emscp_cons t0 e1)
H3 : eq (trans_scp t) t'
Typr Γ (trans_scp t) Ty_nat
Now, I'd like to perform a case analysis on the scrutinee in the match
expression but
destruct
(gdscpof (open_scp O (cons (Tm_fvar (freshvar S.empty)) nil) e1)
(cons (pair (freshvar S.empty) Ty_nat) empty)) in H2.
just brings an additional hypothesis
g : gdscp
with noting else changed. Looks like destruct does not find the
intended term.
I could track down the problem to the following error message:
When I issue the command in the context above
set (F:=(pair (freshvar S.empty) Ty_nat)) in H2.
Coq returns:
Error: The term "pair (freshvar S.empty) Ty_nat" does not occur in H2.
This is absolutely puzzling to me, since I can clearly see this term.
I am able to replace other term like "Tm_fvar (freshvar S.empty)" in
the matched expression but not the pair-term.
I have no clue what I am missing here. If additional information is
required to track down the problem, I'll be happy to provide it.
Any help is very much appreciated, thanks in advance,
best regards,
Florian
Florian Lorenzen
Technische Universität Berlin
Fakultät IV - Elektrotechnik und Informatik
Übersetzerbau und Programmiersprachen
Sekr. TEL12-2, Ernst-Reuter-Platz 7, D-10587 Berlin
Tel.: +49 (30) 314-24618
E-Mail:
WWW: http://www.user.tu-berlin.de/florenz/
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk9L/4IACgkQvjzICpVvX7ZtFQCdEUyEdFlyY57KiUuB6IWbgyaj
a2QAniwVGDbBor5sswVRoy+7l0yvq0ek
=0POl
-----END PGP SIGNATURE-----
- [Coq-Club] Strange problem with `destruct' tactic, Florian Lorenzen
- Re: [Coq-Club] Strange problem with `destruct' tactic,
AUGER Cédric
Florian Lorenzen
- Re: [Coq-Club] Strange problem with `destruct' tactic, AUGER Cédric
Florian Lorenzen
AUGER Cédric
