- From: Jacques Garrigue <garrigue AT math.nagoya-u.ac.jp>
- To: yannick_duchene AT yahoo.fr
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq, SML and Ada
- Date: Fri, 16 Mar 2012 17:11:52 +0900
- Domainkey-signature: a=rsa-sha1; h=Received:Subject:Mime-Version:Content-Type:From:In-Reply-To:Date:Cc:Content-Transfer-Encoding:Message-Id:References:To:X-Mailer; b=HSigp/O1q3YmAg6DB3OWB+FYYIM67qdFdnkR2IRq+Kpfvt7ypU2IiMnos91aUJpkimsFw7DzY5PrkNQ2Ki4sLBNQ/bbNDU0b0BX/s4rwSygZRpNqML8FsvJlH6ix5cp+VOeUlXGYrVTUUwI8cLyXCsf60wmWrDAgx7YNxWMWkB8=; c=nofws; d=math.nagoya-u.ac.jp; q=dns; s=alpha
On 2012/03/01, at 14:48,
wrote:
> Hi all,
> If people don't mind about a beginner question, I have one: one can extract
> an
> Ocaml program from a proved specification. Are there some ways to extract an
> SML program and/or an Ada program?
> If not, if there a kind of semantic API or anything else to help with this?
> And
> is such an attempt, dangerous, useless, difficult?
> I searched the web, but failed to locate relevant materials for that matter.
> With thanks.
> Yannick D.
I'm not aware of any off-the-shelf extraction for either SML or Ada.
There is already support for Haskell and Scheme in addition to OCaml,
and external backends for ruby (already mentioned) and Scala [1].
[1] https://bitbucket.org/yoshihiro503/coq2scala/src
If there is a strong need, I suppose that exporting to SML should not be too
difficult, as extract OCaml code is essentially Core ML + modules, so this is
just about
changing the syntax.
Extraction to Ada seems another problem: how do you encode the lambda-calculus
in Ada?
Jacques Garrigue
- [Coq-Club] Coq, SML and Ada, yannick_duchene
- Re: [Coq-Club] Coq, SML and Ada, Nuno Gaspar
- Re: [Coq-Club] Coq, SML and Ada, Jacques Garrigue
Xavier Leroy
- Re: [Coq-Club] Coq, SML and Ada, Yannick
- Re: [Coq-Club] Coq, SML and Ada, Pierre Letouzey
Xavier Leroy
