coq-club - [Coq-Club] Adding a "map2i" function to FMapAVL/FMapInterface?
chronological Thread
  • From: Valentin ROBERT <valentin.robert AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Adding a "map2i" function to FMapAVL/FMapInterface?
  • Date: Tue, 27 Mar 2012 11:46:57 +0200
Hello coq-club,
I recently found the need for an extended version of FMapInterface's map2 and mapi:
Parameter mapi : (key -> elt -> elt') -> t elt -> t elt'.
Parameter map2 : (option elt -> option elt' -> option elt'') -> t elt -> t elt' -> t elt''.
Namely, map2i:
Parameter map2i : (key -> option elt -> option elt' -> option elt'') -> t elt -> t elt' -> t elt''.
(also called "merge" in OCaml >= 3.12.0)
I have a functor packaging FMapAVL with that new operation and four properties (code given at the end of this email). Now, could that be useful to someone else?
It is not trivial to add this in FMapAVL, since the last two properties are proved using FMapFacts which need FMapAVL to be instantiated.
It is not trivial to put these two bothersome properties in FMapFacts, since, as I understand it, I would need to have map2i in the FMapInterface signature, and then to implement it for every implementation of the signature.
Maybe I could rewrite their proofs without using FMapFacts...
What would be the reasonable way to contribute such a function to the standard library?
Is there a reason why it is not there already? (its implementation is fairly close to map2 in the case of FMapAVL)
Regards,
- Valentin
(*** BEGIN COQ CODE ***)
Module FMapAVL_MAP2I(X: OrderedType).
Module M := FMapAVL.Make(X).
Include M.
Module FMF := FMapFacts.WFacts_fun X M.
Section MAP2I.
Variable elt elt' elt'' : Type.
Variable f : key -> option elt -> option elt' -> option elt''.
Hypothesis f_compat: forall x x' o1 o2, X.eq x x' -> f x o1 o2 = f x' o1 o2.
Definition raw_map2i: Raw.t elt -> Raw.t elt' -> Raw.t elt'' :=
  Raw.map2_opt
    (fun k d o => f k (Some d) o)
    (Raw.map_option (fun k d => f k (Some d) None))
    (Raw.map_option (fun k d' => f k None (Some d'))).
Lemma map2i_bst:
  forall m1 m2, Raw.bst m1 -> Raw.bst m2 -> Raw.bst (raw_map2i m1 m2).
Proof.
  intros. unfold raw_map2i.
  apply Raw.Proofs.map2_opt_bst with (f0 := f); auto; intros.
  apply Raw.Proofs.map_option_bst; auto.
  apply Raw.Proofs.map_option_find; auto.
Qed.
Definition map2i (m1: t elt)(m2: t elt'): t elt'' :=
  Bst (map2i_bst m1.(is_bst) m2.(is_bst)).
Lemma map2i_1: forall (m: t elt)(m': t elt')(x:key),
  In x m \/ In x m' ->
  find x (map2i m m') = f x (find x m) (find x m').
Proof.
  unfold find, map2i, In; intros until x. simpl.
  do 2 rewrite Raw.Proofs.In_alt. unfold raw_map2i. intros.
  rewrite Raw.Proofs.map2_opt_1 with (f0 := f); auto; intros.
  apply is_bst. apply is_bst.
Qed.
Lemma map2i_2: forall (m: t elt)(m': t elt')(x:key),
  In x (map2i m m') -> In x m \/ In x m'.
Proof.
  unfold In, map2i; intros until x.
  do 3 rewrite Raw.Proofs.In_alt. simpl. unfold raw_map2i; intros.
  eapply Raw.Proofs.map2_opt_2 with (f0 := f); eauto; intros.
Qed.
Lemma map2i_3: forall x m1 m2,
  (forall k, f k None None = None) ->
  find x m1 = None ->
  find x m2 = None ->
  find x (map2i m1 m2) = None.
Proof.
  intros. destruct (find x (map2i m1 m2)) as []_eqn; [|auto].
  assert (find x (map2i m1 m2) <> None). congruence.
  apply FMF.in_find_iff in H2. apply map2i_2 in H2. inv H2.
  apply FMF.in_find_iff in H3. congruence.
Qed.
Lemma map2i_4: forall m m' (H: forall k, f k None None = None) x,
Proof.
  intros. destruct (find x m) as []_eqn.
  rewrite <- Heqo. apply map2i_1. left. apply FMF.in_find_iff. congruence.
  destruct (find x m') as []_eqn.
  rewrite <- Heqo. rewrite <- Heqo0. apply map2i_1. right.
  rewrite H. apply map2i_3; auto.
Qed.
End MAP2I.
End FMapAVL_MAP2I.
