coq-club - Re: [Coq-Club] Finding subformulas.
chronological Thread
  • From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
  • To: Bernard Hurley <bernard AT marcade.biz>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Finding subformulas.
  • Date: Fri, 6 Apr 2012 11:50:10 +0100
Hi Bernard,
If you have the property you're asking for then A can only
be a base formula. If what you are really looking for is
something like
(Subformula A B!C) <-> (Subformula A B) \/ (Subformula A C) \/ A = B!C
then the following inductive definition should do the trick:
defining a subformula amounts to describing a path from
the root of the big formula down to the root of the small
one.
Inductive SubFormula (f : Formula) : Formula -> Set :=
  | here : SubFormula f f
  | left : forall g h, SubFormula f g -> SubFormula f (g ! h)
  | right : forall g h, SubFormula f h -> SubFormula f (g ! h)
Cheers,
guillaume
On 6 April 2012 10:59, Bernard Hurley
 wrote:
> Hi all,
> Given code like:
> Inductive Formula: Set :=
>    &#952;
>  | F_join: Formula -> Formula -> Formula.
> Notation "x ! y"  := (F_join x y)
>  (at level 20, no associativity).
> Is there any way of defining a predicate Subformula so that, for instance,
> (Subformula  (&#952;!&#952;)  ((&#952;!&#952;)!&#952;))) is True whereas:
> (Subformula  (&#952;!(&#952;!&#952;))  ((&#952;!&#952;)!&#952;))) is False?
> Intuitively the predicate can be defined inductively by:
> (Subformula A B!C) <-> (Subformula A B) \/ (Subformula A C),
> but I can't find any way of actually doing it coq. I think it should be
> fairly
> obvious what I mean by a subformula. Thanks in advance for any help.
> Bernard.
