- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Local Fixpoints
- Date: Sun, 08 Apr 2012 13:28:25 +0100
On Sat, 2012-04-07 at 11:17 -0400, Tom Prince wrote:
> On Sat, 7 Apr 2012 02:36:55 +0200, Bernard
> Hurley<bernard AT marcade.biz>
> wrote:
> > Is it possible to get the effect of a Local prefix with Fixpoint. I
> > searched
> > the email archive but the solution I found (from 1999) doesn't work with
> > the
> > current version of coq.
> I'm not sure what behavior you expect from something like 'Local
> Fixpoint'. 'Local' typically only applies to options or tactic database
> settings. (When used with 'Instance', for example, it doesn't cuase the
> definition to disappear at the end of the block, only the assoicated
> hint.)
Thanks, I have only been using coq for a couple of weeks, so I'm only
just getting used to what it's all about.
> The only method of creating a local definition is with 'Let', which
> causes the definition to be turned into a 'let ... in ...' when the
> section is closed. You can create annonymous fixpoints, using 'fix', and
> then bind them with 'Let', but I'm not sure if this is actually what you
> want to use.
> What is your use case?
I didn't have a use case in mind I'm just trying to learn what the
system can do.
Bernard.
- [Coq-Club] Local Fixpoints, Bernard Hurley
- Re: [Coq-Club] Local Fixpoints,
Tom Prince
- Re: [Coq-Club] Local Fixpoints, Bernard Hurley
Tom Prince
