- To: coq-club AT inria.fr
- Subject: [Coq-Club] syntactial substitution with 'sig'
- Date: Tue, 10 Apr 2012 14:51:03 +0200
Hi,
I wonder why (PS : I'm not a Coq expert at all) I cannot apply (bidirectional)
substitutions between inhabitants of 'sig isConcrete' and '{x : Class |
isConcrete x}'.
My Coq code just simulates the fact that in object-oriented programming, one
cannot instantiate an "abstract" class.
Any idea? Thanks in advance...
Require ListSet.
Require Import String.
Open Scope list_scope.
Open Scope string_scope.
Definition isAbstract_label : string := "isAbstract".
Definition isComposite_label : string := "isComposite".
Definition class_label := "class".
Definition name_label := "name".
Definition ownedAttribute_label := "ownedAttribute".
Definition type_label := "type".
Definition N := 100.
Inductive Class : Type :=
BBoolean | (* UML Boolean *)
CClass |
PProperty |
instantiate : Class -> string -> Class |
instantiate' : Class -> string -> ListSet.set Property -> Class
with Property : Type :=
Null : Property | (* 'Null' is introduced in the MOF Core Specification,
v2.0, p. 11 *)
set_isAbstract : Property |
set_ownedAttribute : string -> Class -> nat -> nat -> bool -> Property |
attribute name, attribute type, lower bound, upper bound, isComposite or not
set_superClass : Class -> Property.
Definition ownedAttribute(c : Class) : ListSet.set Property := match c with
| BBoolean => nil
| CClass => (set_ownedAttribute isAbstract_label BBoolean 1 1
true)::(set_ownedAttribute ownedAttribute_label PProperty 0 N true)::nil
| PProperty => (set_ownedAttribute isComposite_label BBoolean 1 1
true)::(set_ownedAttribute class_label CClass 0 1 false)::nil
| instantiate _ _ => nil
| instantiate' _ _ l => l
end.
Inductive isAbstract(c : Class) : Prop :=
isAbstractDef : ListSet.set_In set_isAbstract (ownedAttribute c) ->
isAbstract c.
Inductive isConcrete(c : Class) : Prop :=
isConcreteDef : ~ isAbstract c -> isConcrete c.
Lemma CClass_is_concrete : isConcrete CClass.
Proof.
constructor.
intro.
destruct H.
destruct H.
discriminate.
elim H.
discriminate.
trivial.
Qed.
(* 'make_instance' (simplified version only) just creates a class from a
concrete (ie, non abstract) class: *)
Definition make_instance (c : {x : Class | isConcrete x}) (n : string) : Class
:= match c with (* 'sig isConcrete' does not work? *)
exist c' _ => instantiate c' n
end.
Definition ooo := exist (fun x => isConcrete x) CClass CClass_is_concrete.
Definition Object := make_instance (exist (fun x => isConcrete x) CClass
CClass_is_concrete) "Object".
- [Coq-Club] syntactial substitution with 'sig', franck . barbier
- Re: [Coq-Club] syntactial substitution with 'sig',
Adam Chlipala
- Re: [Coq-Club] syntactial substitution with 'sig', Pierre Casteran
Adam Chlipala
