- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Does Coq actively convert things to Prop?
- Date: Thu, 19 Apr 2012 07:18:58 +0200
On Wed, Apr 18, 2012 at 11:03 PM, AUGER Cédric
<sedrikov AT gmail.com>
wrote:
> Definition r : Type := forall x y : A, Q x y.
> isn't type casting simpler than defining Q' ?
> I always found that giving explicitely the type of a symbol at top
> level was nicer that making the reader to mentaly perform the type
> inference.
First, casting to "Type" is not a type annotation because Type is not
a type... Coq gets to choose which one it is, and it can choose Prop.
Second, what about intermediate expressions, how do I type those?
Frederic makes a similar observation:
> I agree with Andrej that this is not a desirable property to do type
> inference when a type is explicitly given.
Again, and I was confused about this yesterday, Type is not a real
type, so annotating with Type is not a real type annotation. Coq still
has to infer something, namely the level, and as Hugo explained to me,
the levels go
Prop < Set < ... < Type(k) < ... Coq picks the lowest available.
With kind regards,
Andrej
- Re: [Coq-Club] Does Coq actively convert things to Prop?, (continued)
Frederic Blanqui
Arnaud Spiwack
Andrej Bauer
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Andrej Bauer
Arnaud Spiwack
Andrej Bauer
Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, AUGER Cédric
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frederic Blanqui
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Pierre Courtieu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Bernard Hurley
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Randy Pollack
Bernard Hurley
Andrej Bauer
Andrej Bauer
Stéphane Glondu
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Frédéric Tuong
Arnaud Spiwack
Frederic Blanqui
Guillaume Brunerie
- Re: [Coq-Club] Does Coq actively convert things to Prop?, Michael Shulman
