- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "list Set is not coercible to list Type"
- Date: Sun, 22 Apr 2012 07:56:15 -0400
Vladimir Voevodsky wrote:
But that should not be a problem here. Isn't "Set" a particular instance of
"Type"?
Yes, it is, but I don't see why that implies the below problem shouldn't show up. Coq doesn't claim to provide _complete_ type inference.
On Apr 20, 2012, at 6:08 PM, Adam Chlipala wrote:
On 04/20/2012 05:08 PM, Thomas Braibant wrote:
I encountered the following behavior, which I find strange....So you expect [list] to be recognized as covariant in its parameter,
Inductive b : Type := t1 | t2.
Inductive I : list Type -> Type -> Type :=
| C : I (b :: b :: nil) unit.
The term "I" of type "list Type -> Type -> Type"
cannot be applied to the terms
"b :: b :: nil" : "list Set"
"b" : "Set"
The 1st term has type "list Set" which should be coercible to "list Type".
Could someone explain me what's happening ?
subtyping-wise? That would be an interesting feature which I can believe
could be justified semantically, but I don't think it's in today's Coq. It
would certainly complicate the metatheory, and probably wouldn't apply very
often.
In your specific case, you can just replace the second definition with:
| C : I ((b : Type) :: (b : Type) :: nil) unit.
...or use some other method for forcing the implicit parameters of [cons] to
be different.
It's an interesting coincidence that you bring this issue up so soon after
the previous question relating to fake universe polymorphism in Coq! The
specific consequence of such polymorphism here is that the type [b] is
interpreted as being at the lowest possible universe level, [Set].
- [Coq-Club] "list Set is not coercible to list Type", Thomas Braibant
- Re: [Coq-Club] "list Set is not coercible to list Type",
Adam Chlipala
Vladimir Voevodsky
- Re: [Coq-Club] "list Set is not coercible to list Type", Adam Chlipala
Lucian M. Patcas
Vladimir Voevodsky
Adam Chlipala
