- From: Jonas Oberhauser <s9joober AT googlemail.com>
- To: Bernard Hurley <bernard AT marcade.biz>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A question on matching.
- Date: Mon, 23 Apr 2012 20:43:16 +0200
Chad and Smolka showed me lt_eq_lt_dec and le_gt_dec:
http://coq.inria.fr/stdlib/Coq.Arith.Compare_dec.html
2012/4/22 Bernard Hurley
<bernard AT marcade.biz>:
> Hi Gallais,
> Thanks, that's great! Thanks for replying so promptly too!
> Bernard.
> On Sun, Apr 22, 2012 at 07:11:32PM +0100, gallais @ ensl.org wrote:
>> Hi Bernard,
>> Using [nat_compare] does the job. It maps two natural
>> numbers to an element of [comparison] which is either
>> Lt, Eq or Gt (with the obvious semantics).
>> Cheers,
>> Require Import Arith.
>> Variable n : nat.
>> Variable A : Type.
>> Variable a b c : A.
>> Fixpoint test (m: nat):=
>> match nat_compare m n with
>> | Lt => a (*return something*)
>> | Eq => b (* return something *)
>> | Gt => c (* return something *)
>> end.
>> gallais
>> On 22 April 2012 19:00, Bernard Hurley
>>Â <bernard AT marcade.biz>
>> wrote:
>> > Hi,
>> > How would I match [m] so that I could write a Fixpoint with the format?
>> > Variable n: nat.
>> > match m with
>> > | (* m less than n *) => (*return something*)
>> > | (* m equals n *) => (* return something *)
>> > | _ => (* return something *)
>> > end.
>> > Cheers,
>> > Bernard.
- [Coq-Club] A question on matching., Bernard Hurley
- Re: [Coq-Club] A question on matching.,
gallais @ ensl.org
Bernard Hurley
- Re: [Coq-Club] A question on matching., Jonas Oberhauser
Bernard Hurley
gallais @ ensl.org
