- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: How to Repeatedly Apply of a Tactic
- Date: Thu, 26 Apr 2012 10:38:06 +0200
I second that.
If I understand it correctly, it's an issue I find myself often into: I do a
case analysis on some variable, which spawns dozens of cases, all of which
require some particular treatment *in the beginning*, but then are all
resolved
in a similar fashion. Since the initial tactics are different, it's quite hard
to compose using semicolon and brackets, but afterwards I end up repeating 10
lines of simple tactics for each goal (since they are already split in
different subgoals, there's not much semicolon can do).
I resorted to using some "local Ltac definitions" inside the lemmas, but they
are ugly and they survive the end of the lemma (which forces me to choose
different names each time). Is there a more elegant solution? Like some
multi-goal repeat (that applies not only to the current goal, but to each goal
that appears after the previous one was solved, until the current goal cannot
be solved)? Or a reason that such a beast should not exist?
- Re: [Coq-Club] Re: How to Repeatedly Apply of a Tactic, coqletsgo
- Re: [Coq-Club] Re: How to Repeatedly Apply of a Tactic, Adam Chlipala
