- From: Vincent Siles <vincent.siles AT ens-lyon.org>
- To: Bernard Hurley <bernard AT marcade.biz>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Polymorphism in Coq.
- Date: Mon, 30 Apr 2012 08:39:05 +0200
Section myNat.
Parameter B: Set (* or Type, as you wish *)
Parameter plusB : B -> B -> B.
Definition some_code_using_B_and_plusB := .....
End myNat.
Check some_code_using_B_and_plusB.
With this you will define your code with "plusB" as an argument, so that you
can
feed it with plus for nat, or Z, or Q, or whatever has the type B -> B
-> B for some type B.
It is equivalent to directly write
Definition foo (B: Type) (plusB: B -> B -> B) (other args ...) := .....
Hope it helps,
V.
2012/4/30 Bernard Hurley
<bernard AT marcade.biz>:
> Hi.
> I have a set [B] with and a Fixpoint [plus_B:B->B->B]. I also have a lot
> of code written in two parts that are identical except that in one I am
> using [nat] and [plus] and in the other I am using [B] and [plus_B]. Is
> there any way of writing this polymorphically?
> Cheers,
> Bernard.
- [Coq-Club] Polymorphism in Coq., Bernard Hurley
- Re: [Coq-Club] Polymorphism in Coq., Vincent Siles
- Re: [Coq-Club] Polymorphism in Coq., Bernard Hurley
Daniel Schepler
