- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Questions about Extraction Implicit
- Date: Mon, 30 Apr 2012 10:31:51 +0200
Le Thu, 26 Apr 2012 11:39:41 -0700,
Daniel Schepler
a écrit :
> Suppose I define a bst_insert function as in the attached file, and
> then in the extraction I want to drop the l and r parameters in the
> binary_search_tree type and the bst_insert function. First of all,
> this doesn't work the way I'd expect:
> Extraction Implicit empty_bst [l r].
> Extraction Implicit bst_node [l r].
> It looks like it's making nothing implicit in empty_bst, and the wrong
> arguments implicit in bst_node. (Looks like a probable bug.) I can
> fix that by instead saying:
> Extraction Implicit empty_bst [1 2].
> Extraction Implicit bst_node [1 2].
Neither of them works on my coq version (an "old" 8.4 trunk)
> Then the extraction of the binary_search_tree type looks like what I'd
> expect. But I haven't been able to find any Extraction Implicit
> declarations which will allow bst_insert to extract, using either
> parameter names or parameter numbers.
> Also, on a minor note, would there be any way to get rid of the type
> dependency in comparison_pf, which doesn't make sense in the extracted
> version?
> (All this is using 8.3pl4.)
I think you cannot naïvely remove [l] and [r] from binary_search_tree
without having bad surprises.
Consider the following code:
Definition ub l r (t : binary_search_tree l r) : option A :=
match t with
| empty_bst _ up => up
| bst_node _ up _ _ _ _ => up
end.
End binary_search_tree.
Extraction ub.
»let ub l r = function
»| Empty_bst (l0, up) -> up
»| Bst_node (l0, up, x, b, b0) -> up
Of course it is equivalent to the following one:
match t with
| empty_bst _ _ => r
| bst_node _ _ _ _ _ _ => r
end.
But I think that the Extraction should do some quite smart things to
realise it and translate it into a code without which does not require
[l] and [r] as indice.
Of course, you could define an extraction as a partial function,
allowed to fail when such a case is encountered, but that also means,
that you will lose some kind of modularity.
For recursive patterns, you need to provide arguments in the same order
(for reasons which are unknown to me).
That is:
Notation "{ x , .. , z } @> f" :=
((.. (f x) ..) z)
(at level 3).
works, but not:
(reverse_appl z (.. (reverse_appl x f) ..))
(at level 3).
I guess a patch for that would be easy to provide.
(* Can't get this to work...
Notation "( x , y , .. , z ) @> f" :=
(reverse_appl z .. (reverse_appl y (reverse_appl x f)) ..)
(left associativity, at level 91).
- [Coq-Club] Questions about Extraction Implicit, Daniel Schepler
- Re: [Coq-Club] Questions about Extraction Implicit, AUGER Cédric
- Re: [Coq-Club] Questions about Extraction Implicit, Daniel Schepler
