coq-club - Re: [Coq-Club] Functions that differ at exactly one point
chronological Thread
  • From: Jonas Oberhauser <s9joober AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Functions that differ at exactly one point
  • Date: Sun, 29 Apr 2012 19:27:48 +0200
Definition g f m n := if eq_nat_dec n m then 2 else f n.
Using Coq.Arith.Peano_dec
2012/4/29 Bernard Hurley
<bernard AT marcade.biz>:
> Hi all,
> If I have a function [f: nat -> nat], It is easy to define a function
> that differs at just one point in its domain as in:
>  Variable f : nat -> nat.
>  Fixpoint g (n : nat) : nat :=
>    match n with
>      | 55 => 2
>      | _ => f n
>    end.
> But is it possible to define a function that differs at an arbitrary
> integer as the following incorrect code is trying to do:
>  Variable m : nat.
>    match n with
>      | m => 2
>      | _ => f n
>    end.
> Intuitively, since equality is decidable in [nat], there should be some
> way of doing this.
> Thanks,
> Bernard.
