coq-club - Re: [Coq-Club] Recursive identify function
chronological Thread
  • From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
  • To: "<gmalecha AT cs.harvard.edu>" <gmalecha AT cs.harvard.edu>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Recursive identify function
  • Date: Wed, 2 May 2012 06:43:16 +0000
  • Accept-language: en-GB, en-US
Thanks Gregory. If I unfold map in your solution, I more or less get
Fixpoint g (c : C) : C :=
   match c with |
      Build_C x => Build_C (
         (fix h (l : list C) : list C :=
            match l with |
               nil => nil |
               c' :: l' => g c' :: h l'
         end) x)
   end.
What I'm interested to know is how this differs from
Fixpoint h (l : list C) : list C :=
   match l with |
      nil => nil |
      c :: l' => g c :: h l'
   end
with g (c : C) : C :=
   match c with |
      Build_C x => Build_C (h x)
   end.
Is Coq being conservative in rejecting the latter definition?
Regards,
Jeff.
On 1 May 2012, at 22:03, Gregory Malecha wrote:
Hi, Jeffrey --
Coq has some special cases for list functions, so it turns out that this definition works:
Fixpoint h (c : C) : C :=
  match c with
    | Build_C x => Build_C (map h x)
  end.
Hope this helps.
On Tue, May 1, 2012 at 4:37 PM, Terrell, Jeffrey <jeffrey.terrell AT kcl.ac.uk> wrote:
Hi,
Given
Inductive C : Set :=
   Build_C : list C -> C.
how would you define a function with the same functionality as
Definition f (c : C) : C := c
but which constructed its return value recursively? Presumably Coq won't accept
   match l with |
      nil => nil |
   end
   match c with |
   end.
because it cannot be sure that the function will terminate.
Thanks.
Regards,
Jeff.
gregory malecha
