- From: Hendrik Tews <(e29315a54f%hidden_head%e29315a54f)tews(e29315a54f%hidden_at%e29315a54f)os.inf.tu-dresden.de(e29315a54f%hidden_end%e29315a54f)>
- To: David MENTRE <(e29315a54f%hidden_head%e29315a54f)dmentre(e29315a54f%hidden_at%e29315a54f)linux-france.org(e29315a54f%hidden_end%e29315a54f)>
- Cc: Coq Club <(e29315a54f%hidden_head%e29315a54f)coq-club(e29315a54f%hidden_at%e29315a54f)inria.fr(e29315a54f%hidden_end%e29315a54f)>
- Subject: Re: [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath
- Date: Wed, 09 May 2012 14:08:23 +0200
I am sorry for the late reply, sometimes I don't have the time to
follow this list.
David MENTRE
writes:
Versions used:
* The Coq Proof Assistant, version 8.3pl2 (August 2011)
* ProofGeneral 3.7
* GNU Emacs 23.3.1
* System: Ubuntu Linux 11.10 (oneiric)
Proof General in Debian stable, Ubuntu and probably many other
Debian derivatives is completely outdated. However, the package
in Debian testing is up-to-date (prerelease of Proof General 4.2)
and has very light dependencies. You should be able to install
this package after installing mmm-mode.
I added following lines in my .emacs:
;; For ProofGeneral mode
(setq coq-version-is-V8-0 nil)
(setq coq-version-is-V8-1 t)
(setq coq-prog-name "coqtop")
(setq coq-load-path '("/usr/local/lib/why3/coq"
"/usr/local/lib/why3/coq/int"
"/usr/local/lib/why3/coq/real"))
coq-load-path has been added in Proof General 4.1, it has no
effect on older versions.
2. I load ProofGeneral with M-x proofgeneral (apparently a Debian
specific configuration)
This is necessary for Proof General packages 3.7 and earlier. The
new packages don't need this.
Bye,
Hendrik
- Re: [Coq-Club] ProofGeneral for Coq: issue to setup a specific loadpath, Hendrik Tews, 05/09/2012
