coq-club - [Coq-Club] Re: [Agda] Re: strict unit type
  • From: Andreas Abel <(e29315a54f%hidden_head%e29315a54f)andreas.abel(e29315a54f%hidden_at%e29315a54f)ifi.lmu.de(e29315a54f%hidden_end%e29315a54f)>
  • To: Vladimir Voevodsky <(e29315a54f%hidden_head%e29315a54f)vladimir(e29315a54f%hidden_at%e29315a54f)ias.edu(e29315a54f%hidden_end%e29315a54f)>
  • Cc: Coq-Club Club <(e29315a54f%hidden_head%e29315a54f)coq-club(e29315a54f%hidden_at%e29315a54f)inria.fr(e29315a54f%hidden_end%e29315a54f)>, agda list <(e29315a54f%hidden_head%e29315a54f)agda(e29315a54f%hidden_at%e29315a54f)lists.chalmers.se(e29315a54f%hidden_end%e29315a54f)>
  • Subject: [Coq-Club] Re: [Agda] Re: strict unit type
  • Date: Thu, 10 May 2012 09:31:44 +0200
On 10.05.12 1:11 AM, Vladimir Voevodsky wrote:
On May 1, 2012, at 3:51 AM, Andreas Abel wrote:
On 30.04.12 3:36 PM, Vladimir Voevodsky wrote:
PS There is another non-confluent situation with a ->    tt
for a : Pt which does not require dependent sums namely
\lambda x:T, f x where f : T ->    Pt reduces both to f and
to \lambda x:T tt . Both non-confluences can be taken care of
by additional reductions in particular the reduction \prod
x:T, Pt ->    Pt for the example with \lambda.
Such a reduction is unhealthy except in the situation where
\prod is a "for all" that does not leave marks on the term
level.
Well, that was my first thought as well but I am not so sure now.
It does make it necessary to do some type checking before
beta-reduction but anyhow the reduction such as a ->   tt for
objects of the unit type makes reduction context dependent. I
have not checked all the details yet but it is possible that one
can preserve confluence and normal form and still have reductions
which change the sum/prod-structure of type expressions.
I agree that this can likely be modeled, i.e., terms and types can
be interpreted in a way that these reductions become identities.
Partially, this is done in Werner et al.'s proof irrelevant model
of the CIC.
However, I am not so convinced that reduction is the right method
in this case.  For instance, subject reduction fails unless you
work on equivalence classes of types.  A more "semantic" approach
seems more fitting, from my experience.  Also, from the
implementor's perspective such reductions complicate the picture.
For instance, the problem
tt : \prod x:T. Y(x)    with Y a meta-variable
cannot be decided at the spot, but has to wait for the solution of
Y. Also, then a term has many types, which makes type inference
more complicated.
In the system which I am trying to write up there is a typing
function on terms i.e. for any o-term X (object like term) and any
function \Gamma assigning t-terms (type-like terms) to the free
variables in  X there is a simply computed t-term \tau_{\Gamma}(X)
which, if everything happened to be derivable gives a canonical
representative to the type of X.
The fact that there can be many t-terms which are definitionally
equal to \tau_{\Gamma}(X) seems unavoidable in any system with
universes.
Ah, sorry, my statement was imprecise. Of, course, you have many different types for an object, but usually they share a common shape. For instance, Pi-types are only convertible to types whose weak head normal form is again a Pi-type. (And then domains and codomains are convertible in turn.) Frederic Blanqui mentioned this injectivity of Pi-type principle in an answer to your message on the TYPES list.
With your reductions you abandon the preservation of type shapes, because a Pi-type can be equal to a base type like Pt. Your type inference function
  infer(Gamma |- e)
for a context Gamma and an o-term e has to take this into account. E.g. if Gamma = x:Pt, y:Nat and you query
  infer(Gamma |- x y)
then
  infer(Gamma |- x) = Pt   and   infer(Gamma |- y) = Nat
and to justify
  infer(Gamma |- x y) = Pt
you have to *expand* Pt = (Nat -> Pt). Of course, your algorithm does not really need to expand, but to justify your algorithm, you cannot work with a theory of reduction alone.
For practical reasons in Agda (as opposed to Coq and SML), we do not work with inference alone. This is because terms from which you can compute their type by an infer function contain a lot of redundant type information (if inference is compositional). For instance, in application
  infer(Gamma |- f) = Pi x:A.B    infer(Gamma |- e) = A'
one needs to check A = A' before concluding
  infer(Gamma |- f e) = B[e/x]
In bidirectional typing (see also Epigram, Haskell, Matita), type information is propagated more flexibly. For instance, application looks like
  infer(Gamma |- f) = Pi x:A.B   check(Gamma |- e : A)
Here, the domain type A of f is used to check the argument e, allowing e to omit certain type annotations. E.g. if e = lambda y:A_1. e', then the A_1 can be reconstructed from the A and does not have to be stored.
Cheers,
Andreas
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
http://www2.tcs.ifi.lmu.de/~abel/
  • [Coq-Club] Re: [Agda] Re: strict unit type, Andreas Abel, 05/10/2012
