- To: coq-club AT inria.fr
- Subject: [Coq-Club] Mutual induction with list
- Date: Sun, 20 May 2012 00:30:14 -0700
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
How do you have induction over a data structure
that contains a list?
Here is what I want to induct over:
Inductive BlueTree : Set :=
| BlueLeaf
| RedLeaf
| Branch (a : list BlueTree)
I need the assumption that the list elements have
the property when I get to them since they are structurally smaller.
If I put a list as part of the data structure, I can do this:
| BlueLeaf
| RedLeaf
| Branch (a : List)
with List : Set :=
| Nil
| Cons (a : BlueTree) (b : List)
Scheme BlueTree_List_ind := Induction for BlueTree Sort Prop
with List_BlueTree_ind := Induction for List Sort Prop.
or, similarly,
Theorem BlueTree_List_ind : forall (P : BlueTree -> Prop) (P0 : List -> Prop),
P BlueLeaf ->
P RedLeaf ->
(forall a : List, P0 a -> P (Branch a)) ->
P0 Nil ->
(forall a : BlueTree, P a -> forall b : List, P0 b -> P0 (Cons a b)) ->
forall b : BlueTree, P b
intros.
refine ((
fix F (b : BlueTree) : P b := _
with F0 (l : List) : P0 l := _
for F
) b).
apply F.
apply F0.
Qed.
However, I can't seem to translate this back to the original data structure.
Theorem BlueTree_list_ind : forall (P : BlueTree -> Prop) (P0 : list BlueTree
- -> Prop),
P BlueLeaf ->
P RedLeaf ->
(forall a : list BlueTree, P0 a -> P (Branch a)) ->
P0 nil ->
(forall a : BlueTree, P a -> forall b : list BlueTree, P0 b -> P0 (a::b)) ->
intros.
refine ((
with F0 (l : list BlueTree) : P0 l := _
for F
) b).
Error: Fixpoints should be on the same mutual inductive declaration.
I'm not sure what that means. I guess that means that both parts
of the data structure should be defined in the same statement with a
with clause? How do I use a plain, existing list?
Is that possible?
$_="sccc,gB1,a_oo,JosBackuSa,g11,ug1a,oscc,cBBg,JcgaBuucaB_s11_Juc_c";
while(($c,$b,$a)=m/^(.)([^,]*),(.*)$/){$_=$a;s/$c/$b/g;}
print map chr length,split /_/;
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+4nYYACgkQxzVgPqtIcfvfLgCeKnftO9wrJO8Gh/nDSsB8GJht
RWIAnA7PAaTenPlMJ8r1Llej9anB15/p
=/MmH
-----END PGP SIGNATURE-----
- [Coq-Club] Mutual induction with list, S3, 05/20/2012
- Re: [Coq-Club] Mutual induction with list, Adam Chlipala, 05/20/2012
- Re: [Coq-Club] Mutual induction with list, S3, 05/20/2012
- Re: [Coq-Club] Mutual induction with list, S3, 05/21/2012
- Re: [Coq-Club] Mutual induction with list, Frédéric Besson, 05/21/2012
