- From: Leonard Siebeneicher <l-siebeneicher AT versanet.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club]
- Date: Sun, 20 May 2012 17:47:51 +0200
Hi Thomas,
thank you for your answer. I needed some time to answer, because I tried myself to get something working using OrderedTypeAlt.
You asked about the idea behind.
Instead of using a nat as key for a FMap of strings, numbers or tuples, I rather like to use own types for each FMap.
(FMap//stringKey -> string ) instead of (FMap//nat -> string)
(FMap//tupleKey -> nat,nat) instead of (FMap//nat -> nat,nat)
(FMap//integerKey -> integer) instead of (FMap//nat -> integer)
Using a functor I like to generate new types for such Keys automatically for a type.
Module Type TypDesc....
Parameter t.
End TypDesc.
Module GenerateKey (D : TypDesc) <: OrderedType....
(D: TypDesc) is only dummy. It is not used within GenerateKey. But, it makes Coq generating a new type automatically
End GenerateKey.
But, (D:TypDesc) is used within this module.
Module EncapsulatedMap (D : TypDesc).
Module KeyTypes := GenerateKey (D).
Module Map := FMapAVL.Make(KeyTypes).
Definition itsMap := Map.t (D.t).
End EncapsulatedMap.
Given some modules (itsANatTuple : TypDesc) (itsAString : TypDesc) we can do
Module TupleMap := EncapsulatedMap (itsANatTuple).We cannot use a key from StringMap to access tuples from TupleMap. Because, they have different types. Thats the idea behind it.
Module StringMap := EncapsulatedMap (itsAString).
Am still struggling with equations.
I thing I lack some fundamental knowledge about how to use Proof-Mode.
Below is a try, to define a Module out of OrderedTypeAlt.
Best Regards,
Leonard.
(* BEGIN COQ-FILE "StrugglingWithOTA.v" *)
Require Import Structures.OrderedTypeAlt.
Require Import Structures.OrderedTypeEx.
Module Type KeyTarget.
Parameter t : Type.
End KeyTarget.
Module MyKey (K : KeyTarget) <: OrderedTypeAlt.
Inductive a_key := key : nat -> a_key.
Definition t := a_key.
Definition compare (k1 k2 : a_key) : comparison :=
match (k1,k2) with
| (key n1, key n2) => NatOrderedType.Nat_as_OT.compare n1 n2
end.
Infix "?=" := compare (at level 70, no associativity).
Definition compare_sym :
forall x y, (y?=x) = CompOpp (x?=y).
Proof.
intros x y.
induction x; induction y.
induction n; induction n0.
unfold "?="; simpl; auto.
(* how to get out of recursion ... still learning *)
Qed.
Definition compare_trans :
forall c x y z, (x?=y) = c -> (y?=z) = c -> (x?=z) = c.
Proof.
intros c x y z.
induction x; induction y; induction z.
intros H1 H2.
symmetry in H1.
symmetry in H2.
rewrite H1.
(* struggling again. Need to understand how to deal with equalities in Coq? *)
Qed.
End MyKey.
(* END COQ-FILE "StrugglingWithOTA.v" *)
- [Coq-Club], l-siebeneicher, 05/12/2012
- Re: [Coq-Club], Leonard Siebeneicher, 05/15/2012
- Message not available
- Re: [Coq-Club], Leonard Siebeneicher, 05/20/2012
