- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Need help to simplify / prove properties of my code
- Date: Sat, 26 May 2012 09:37:12 -0700
Even though I came up with all this myself, and it obviously results in the
expressions I wanted, I'm still not sure I understand how it actually works.
For example, would there be any way to flatten the definitions to using a
single
level of the continuation passing monad? Also, I'm stuck trying to prove a
couple simple example properties which I know must be true...
Ultimately, I'd want to convert these definitions to typeclass instances,
with
the goal to be able to write things like "open (fun x y:R => x*x + y*y < 1)",
or eventually "continuous Rplus".
Class Bind (X' X Y:Type) : Type :=
bind : X' -> (X -> Y) -> Y.
Class Return (X Y:Type) : Type :=
return_ : X -> Y.
Class MonadAlgebraSignature (m:Type -> Type) (X:Type) : Type :=
monad_alg_bind :> forall Y:Type, Bind (m Y) Y X.
Instance prod2_algebra (m:Type -> Type) (X Y:Type)
`{MonadAlgebraSignature m X} `{MonadAlgebraSignature m Y} :
MonadAlgebraSignature m (X * Y) :=
fun A (a:m A) (f:A -> X * Y) =>
(bind a (fun a' => fst (f a')), bind a (fun a' => snd (f a'))).
Instance prod_algebra (m:Type -> Type) (X:Type) (P:X->Type)
`{forall x:X, MonadAlgebraSignature m (P x)} :
MonadAlgebraSignature m (forall x:X, P x) :=
fun A (a:m A) (f:A -> forall x:X, P x) (x:X) =>
bind a (fun a' => f a' x).
Instance func_space_algebra (m:Type -> Type) (X Y:Type)
`{MonadAlgebraSignature m Y} : MonadAlgebraSignature m (X->Y).
Class MonadSignature (m:Type -> Type) : Type := {
monad_bind :> forall X:Type, MonadAlgebraSignature m (m X);
monad_return :> forall X:Type, Return X (m X)
Definition continuation (R:Type) : Type -> Type :=
fun X => (X -> R) -> R.
Instance cont_result_monad_alg (R:Type) :
MonadAlgebraSignature (continuation R) R :=
fun Y y => y.
Instance cont_monad (R:Type) : MonadSignature (continuation R) := {|
monad_bind := fun X Y (y:continuation R Y) (f:Y -> continuation R X)
(cont : X -> R) => y (fun y0 => f y0 cont);
monad_return := fun X (x:X) (cont : X -> R) => cont x
Notation "x >>= f" := (bind x f) (left associativity, at level 91).
Notation "'do' x0 <- x ; y" := (x >>= (fun x0 => y))
(right associativity, at level 92, x0 ident).
Notation "x >> y" := (do _ <- x; y) (left associativity, at level 91).
Definition topspace : Type := { X:Type & (X->Prop) -> Prop }.
Require Import List.
Open Scope list_scope.
Fixpoint subset_type (l : list topspace) : Type :=
match l with
| nil => Prop
| (existT X _) :: l' => X -> subset_type l'
end.
Instance subset_type_alg (l : list topspace) :
MonadAlgebraSignature (continuation Prop) (subset_type l).
induction l as [ | [X Xopen] l' ]; typeclasses eauto.
Defined.
Fixpoint nhd_builder {l:list topspace} :
continuation Prop (continuation Prop (subset_type l)) -> subset_type l :=
match l with
| nil => fun P => do Q <- P; do R <- Q; R
| (existT X Xopen) :: l' => fun U =>
fun x:X => nhd_builder (fun cont1 => do U' <- U;
exists A : X -> Prop, A x /\ Xopen A /\
cont1 (fun cont2 => do U'' <- U';
forall x':X, A x' -> cont2 (U'' x')))
end.
Definition multidim_nhd {l:list topspace} : subset_type l -> subset_type l :=
fun U => nhd_builder (return_ (return_ U)).
Eval compute in (fun X Xopen Y Yopen Z Zopen => @multidim_nhd
(existT _ X Xopen :: existT _ Y Yopen :: existT _ Z Zopen :: nil)).
Fixpoint open_builder {l:list topspace} :
subset_type l -> continuation Prop (continuation Prop (subset_type l)) ->
Prop :=
match l with
| nil => fun P Q =>
P -> (do Q' <- Q; do Q'' <- Q'; Q'' : Prop)
| existT X Xopen :: l' => fun U V =>
forall x:X, open_builder (U x) (fun cont1 => do V' <- V;
cont1 (fun cont2 => do V'' <- V';
forall x':X, A x' -> cont2 (V'' x')))
end.
Definition multidim_open {l:list topspace} : subset_type l -> Prop :=
fun U => open_builder U (return_ (return_ U)).
Eval compute in (fun X Xopen Y Yopen Z Zopen => @multidim_open
Fixpoint contained {l:list topspace} :
subset_type l -> subset_type l -> Prop :=
match l with
| nil => fun P Q => P -> Q
forall x:X, contained (U x) (V x)
end.
Lemma multidim_nhd_contained (l:list topspace) : forall U:subset_type l,
contained (multidim_nhd U) U.
Proof.
fun U x y z ... Hnhd => match Hnhd with
| ex_intro A (conj Ax (conj Aopen
(ex_intro B (conj By (conj Bopen
(ex_intro C (conj Cz (conj Copen ... Hinc)))))))) =>
Hinc x Ax y By z Cz ...
end.
admit.
Qed.
Lemma multidim_nhd_open (l:list topspace) : forall U:subset_type l,
multidim_open (multidim_nhd U).
Proof.
admit.
Qed.
- [Coq-Club] Need help to simplify / prove properties of my code, Daniel Schepler, 05/26/2012
