coq-club - [Coq-Club] Generalizing dependently typed functions
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Generalizing dependently typed functions
  • Date: Mon, 28 May 2012 16:34:26 -0400
Hi,
Is there a good way to take
  f : a -> T a a -> Prop
and turn it into
  g : a -> b -> T a b -> Prop
so that we can prove
  f _ x <-> g _ _ x
and
  b <> a -> ~g a b _
Essentially, I want to take [T a a -> Prop] and generalize it to [T a b -> Prop] such that I don't get any new truths that I didn't already have from my original function.
I was able to write the following code which does what I want, but I'm wondering if there's a better/simpler way to do it, and if there's a way to write [cast] so that I don't need [eq_rect_eq] to prove [cast_nop]:
Require Import Eqdep.
Import Eq_rect_eq.
Set Implicit Arguments.
Parameter f : forall T (a : Type), T a -> Prop.
Implicit Arguments f [T a].
Inductive and' (A : Prop) (B : A -> Prop) : Prop :=
  conj' : forall (a : A), (B a) -> @and' A B.
Implicit Arguments and' [].
Definition cast T (a b : Type) : a = b -> T a b -> T a a.
  intro H. rewrite <- H. intro t. apply t.
Defined.
Definition g T (a : Type) (b : Type) (x : T a b) : Prop :=
  and' (a = b) (fun p => f (cast T p x)).
Implicit Arguments g [T a b].
Theorem g_ne T (a b : Type) (x : T a b) : a <> b -> ~g x.
  unfold g; firstorder.
Qed.
Lemma cast_nop T (a : Type) (x : T a a) (p : a = a) : x = cast _ p x.
  unfold cast; rewrite <- eq_rect_eq; reflexivity.
Qed.
Hint Resolve cast_nop.
Theorem f_eq_g T (a : Type) (x : T a a) : f x <-> g x.
  unfold g; firstorder;
    try (
      match goal with
        [ |- (and' (?a = ?a) _) ] => cut (a = a); try solve [ reflexivity ]
      end;
      intro p; apply (@conj' _ _ p)
    match goal with
      [ H : f ?arg1 |- f ?arg2 ] => cut (arg1 = arg2); eauto
    end;
    intro h; rewrite <- h; assumption.
Qed.
Thanks!
-Jason
