coq-club - Re: [Coq-Club] How to remove "Coq <" from coq-tex's output
  • To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to remove "Coq <" from coq-tex's output
  • Date: Tue, 29 May 2012 10:29:26 -0400
I tried
\begin{coq_example*}
Definition f a : Prop := a.
\end{coq_example*}
coq-tex still generated
\begin{flushleft}
\texttt{Coq~{<}~Definition~f~a~:~Prop~:=~a.}\\
\end{flushleft}
Do I need to use any flag?
P.S. Do you know if there is a way to write math symbols in coq example?
Thanks.
On Mon, May 28, 2012 at 5:12 AM, Arnaud Spiwack
wrote:
> You can use the environment coq_example*
> On 26 May 2012 16:50, Jianzhou Zhao
> <jianzhou AT seas.upenn.edu>
> wrote:
>> Hi,
>> The output of coq-tex is by default started with "Coq <" at the
>> beginning of each line. Is there a way to remove "Coq <"? Thanks.
>> Jianzhou
Jianzhou
