- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Anomaly: Cannot take the successor of a non variable universe
- Date: Wed, 30 May 2012 14:23:26 +0200
Anomalies are always bugs on the Coq side, they are always worth reporting. The bug tracker is to be found here : http://www.lix.polytechnique.fr/coq/bugs/ (your bug seems to be new)
As an aside, you seem to be right about the source of the bug, here is a minimal example :
Definition X (A := Type) : A := nat.
The following doesn't cause an error though:
Definition Type1 := Type.
Definition X (A := Type1) : A := nat.
On 29 May 2012 18:20, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,When I execute the last [Qed] in the following code, I getAnomaly: Cannot take the successor of a non variable universe:(maybe a bugged tactic).Please report.I'm pretty sure this is Coq telling me that my [F := A -> Type] is bad (though I'm not sure exactly what's wrong with it). Is this worth reporting, and, if so, where should I report it to? Thanks.Require Import Eqdep.Import Eq_rect_eq.Definition cast a b (p : a = b) : a -> b.intro; rewrite <- p; assumption.Defined.
Implicit Arguments cast [a b].Lemma cast_nop T (p : T = T) (a : T) : cast p a = a.unfold cast; rewrite <- eq_rect_eq; reflexivity.Qed.Lemma cast_app_nop A (F := A -> Type) (pF : F = F) (pA : A = A) (f : F) (a : A) : ((cast pF f) (cast pA a)) = f a.unfold cast; repeat (rewrite <- eq_rect_eq); reflexivity.Qed.
-JasonP.S. I also get it if I replace the proof and the [Qed.] with [admit.]
- [Coq-Club] Anomaly: Cannot take the successor of a non variable universe, Jason Gross, 05/29/2012
- Re: [Coq-Club] Anomaly: Cannot take the successor of a non variable universe, Matthieu Sozeau, 05/30/2012
- Re: [Coq-Club] Anomaly: Cannot take the successor of a non variable universe, Arnaud Spiwack, 05/30/2012
