- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Solving function application
- Date: Thu, 31 May 2012 09:25:39 +0200
Hi Taimoor,
Since your Coq goal comes from the Why3 system, I suggest you send your question to the Why3 Club instead.
To answer your question: since the add0 function is axiomatized, Coq cannot compute with it, so you must perform "evaluation" manually. A tactic like
repeat (rewrite add0_def; auto with *).
might do the job.
- Claude
Le 29/05/2012 14:58,
mtkhan AT risc.jku.at
a écrit :
Hi,
I have the following sketch of the premises of my proof.
Parameter add0: (list or_integer_float) -> Z -> Z -> Z.
Axiom add0_def : forall (e:(list or_integer_float)) (i:Z) (j:Z) ...
H0 : result =
add0
(Cons (Integer 5)
(Cons (Real (33 / 10))
(Cons (Integer 8) (Cons (Real (4 / 10)) (Cons (Integer 9)
Nil)))))
(length
(Cons (Integer 5)
(Cons (Integer 8)
(Cons (Real (4 / 10)) (Cons (Integer 9) Nil))))))
And the goal is
result = 13%Z.
As a matter of fact the goal can easily be proved by just an application of
the function
add0 defined above. But it does not work for me. Can someone help me how we
can
prove such stuff, where we just need to compute the result of a function
application.
Thanks.
tk
Claude Marché | tel: +33 1 72 92 59 69
INRIA Saclay - Île-de-France |
Université Paris-sud, Bat. 650 | http://www.lri.fr/~marche/
F-91405 ORSAY Cedex |
- [Coq-Club] Solving function application, mtkhan, 05/29/2012
- Re: [Coq-Club] Solving function application, Claude Marche, 05/31/2012
