- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Alan Schmitt <alan.schmitt AT polytechnique.org>
- Cc: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>, Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] get the name of the current module in a plugin
- Date: Mon, 25 Jun 2012 11:03:15 -0400
A (quite comprehensive) list of examples of plugins I know of:
- https://github.com/braibant/Timing-plugin (this one is quite simple,
but quite useful for timing tactics)
- http://coq.inria.fr/cocorico/evar_match (now integrated in 8.4, but
nicely commented)
- https://github.com/mattam82/Constructors (not updated for the new
coq_makefile)
- http://coq.inria.fr/cocorico/UnfoldFixpointOnce
- https://github.com/braibant/coq-tutorial-ml-tactics (tutorial on
reification)
- https://github.com/tomprince/rippling (proof automation)
- http://sardes.inrialpes.fr/~braibant/aac_tactics/ (rewriting modulo AC)
- ssreflect (http://www.msr-inria.inria.fr/Projects/math-components)
Reading through the ml code of these may give leads about what to
search for (and I really think that _not_ opening modules would help
a lot to find where things are defined).
> let consts = pe.Pre_env.env_globals.Pre_env.env_constants in
(is backward compatibility with OCaml 3.11 worth it when writing
plugins ? If not, then
let consts = Pre_env.( pe.env_globals.env_constants ) in
is more palatable.)
Hope this helps,
Thomas
- [Coq-Club] get the name of the current module in a plugin, Alan Schmitt, 06/22/2012
- Re: [Coq-Club] get the name of the current module in a plugin, Pierre-Marie Pédrot, 06/25/2012
- Re: [Coq-Club] get the name of the current module in a plugin, Alan Schmitt, 06/25/2012
- Re: [Coq-Club] get the name of the current module in a plugin, Thomas Braibant, 06/25/2012
- Re: [Coq-Club] get the name of the current module in a plugin, Alan Schmitt, 06/26/2012
