- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: Jason Gross <jasongross9 AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Generalized version of [change]/[subst]?
- Date: Mon, 2 Jul 2012 10:29:39 +0200
To complete Arnaud's answer. It is unlikely you want to have a subst
equivalent for non variable terms. subst replaces a variable by it
value everywhete *and then* removes the equality used for that from
the context. This is a tactic "with no loss of information" because it
only works on variables. Doing this with t = u where t and u are two
non variable terms would lose some important information. You can
always do "cear H" if you want to forget a hypothesis H anyway.
Cheers,
Pierre Courtieu
2012/7/2 Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr>:
> replace
> rewrite
> These are what you are looking for.
> On 2 July 2012 06:25, Jason Gross
> wrote:
>> Hi,
>> I was wondering if there's a version of [change] that requires only
>> equality, rather than convertibility, or a version of [subst] that applies
>> to terms and not just identifiers? [change] only works when the terms are
>> convertible, and [subst] only works if one them is an identifier. I wrote
>> a
>> version myself (see below), but I'm wondering if there's something that
>> does
>> this in Coq, already. Thanks.
>> (* equivalent to [change x with y], but requires that [x = y] be provable
>> with [taceq],
>> rather than that [x] and [y] are convertible *)
>> Tactic Notation "generalized_change" constr(x) "with" constr(y) "by"
>> tactic(taceq) :=
>> let xeqy := fresh in
>> assert (xeqy : x = y) by (taceq || symmetry; taceq);
>> let x' := fresh in
>> pose x as x';
>> let xeqx' := fresh in
>> let x'eqy := fresh in
>> assert (xeqx' : x = x') by reflexivity;
>> change x with x';
>> assert (x'eqy : x' = y) by (transitivity y; exact xeqy
>> || symmetry; exact xeqy || trivial);
>> clear xeqx';
>> clearbody x';
>> subst x';
>> clear xeqy.
>> -Jason
- [Coq-Club] Generalized version of [change]/[subst]?, Jason Gross, 07/02/2012
- Re: [Coq-Club] Generalized version of [change]/[subst]?, Arnaud Spiwack, 07/02/2012
- Re: [Coq-Club] Generalized version of [change]/[subst]?, Pierre Courtieu, 07/02/2012
- Re: [Coq-Club] Generalized version of [change]/[subst]?, Jason Gross, 07/02/2012
- Re: [Coq-Club] Generalized version of [change]/[subst]?, Chung-Kil Hur, 07/02/2012
