- To: coq-club AT inria.fr
- Subject: [Coq-Club] Abstracted type constructors and positivity restrictions?
- Date: Mon, 2 Jul 2012 10:19:44 -0400 (EDT)
Hello, I am trying to use the finite map theory (FMapInterface) in a theory
that reasons about explicit substitution semantics (e.g. the CEK machine of
Felleisen-Friedman). I am trying not to marry my reasoning to any one
implementation, for obvious reasons.
There is a problem with this endeavor - the type of abstract maps on line 62
of FMapInterface.v:
Parameter t : Type -> Type.
(** the abstract type of maps *)
Has no definition-site positivity restrictions, so I cannot use t as a type
constructor in a mutually inductive way:
Module CEK_fun (Names : DecidableType)
(Import fmap : FMapInterface.WS with Module E := Names).
Inductive Value : Type :=
| closure : lambda_expression -> Environment -> Value
with Environment :=
| mk_env : fmap.t Value -> Environment.
(* using list instead of fmap.t is completely fine - !! *)
This completely defeats modularity, so that different theories of collections
cannot be effectively defined.
What is the plan for supporting this kind of abstraction? In the meanwhile,
how can I effectively work around this without having to import a specific
implementation?
I have tried allowing heterogeneous types for the fmap, but instantiating at
Value causes a universe circularity.
Thanks,
-J. Ian Johnson
- [Coq-Club] Abstracted type constructors and positivity restrictions?, J. Ian Johnson, 07/02/2012
- Re: [Coq-Club] Abstracted type constructors and positivity restrictions?, Pierre Courtieu, 07/02/2012
- Re: [Coq-Club] Abstracted type constructors and positivity restrictions?, J. Ian Johnson, 07/02/2012
