coq-club - [Coq-Club] Automated Simplification of Definitions
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Automated Simplification of Definitions
  • Date: Mon, 2 Jul 2012 15:57:58 -0400
Hi,
I have some tactics that make complicated definitions, which I'd like to pass through [simpl] and some other simplification mechanisms before storing.  Currently, I have the following code (which mostly comes from Adam):
Set Implicit Arguments.
Section sig.
  Definition sigT2_sigT A P Q (x : @sigT2 A P Q) := let (a, h, _) := x in existT _ a h.
  Global Coercion sigT2_sigT : sigT2 >-> sigT.
  Definition projT3 A P Q (x : @sigT2 A P Q) :=
    let (x0, _, h) as x0 return (Q (projT1 x0)) := x in h.
  Definition sig2_sig A P Q (x : @sig2 A P Q) := let (a, h, _) := x in exist _ a h.
  Global Coercion sig2_sig : sig2 >-> sig.
  Definition proj3_sig A P Q (x : @sig2 A P Q) :=
    let (x0, _, h) as x0 return (Q (proj1_sig x0)) := x in h.
End sig.
Lemma sigT_eta : forall A (P : A -> Type) (x : sigT P),
  x = existT _ (projT1 x) (projT2 x).
  destruct x; reflexivity.
Qed.
Lemma sigT2_eta : forall A (P Q : A -> Type) (x : sigT2 P Q),
  x = existT2 _ _ (projT1 x) (projT2 x) (projT3 x).
Qed.
Lemma sig_eta : forall A (P : A -> Prop) (x : sig P),
  x = exist _ (proj1_sig x) (proj2_sig x).
Qed.
Lemma sig2_eta : forall A (P Q : A -> Prop) (x : sig2 P Q),
  x = exist2 _ _ (proj1_sig x) (proj2_sig x) (proj3_sig x).
Qed.
(* Silly predicate that we can use to get Ltac to help us manipulate terms *)
Definition focus A (_ : A) := True.
(* This definition does most of the work of simplification. *)
Ltac simpl_definition_by_tac_and_exact defn tac :=
  assert (Hf : focus defn) by constructor;
    try unfold defn in Hf; try tac; simpl in Hf;
      repeat match type of Hf with
               | context[match ?E with existT2 _ _ _ => _ end] => rewrite (sigT2_eta E) in Hf; simpl in Hf
               | context[match ?E with exist2 _ _ _ => _ end] => rewrite (sig2_eta E) in Hf; simpl in Hf
               | context[match ?E with existT _ _ => _ end] => rewrite (sigT_eta E) in Hf; simpl in Hf
               | context[match ?E with exist _ _ => _ end] => rewrite (sig_eta E) in Hf; simpl in Hf
             end;
        | focus ?V => exact V
      end.
Ltac simpl_definition_by_exact defn := simpl_definition_by_tac_and_exact defn idtac.
(** To simplify something defined as [Ident'] of type [IdentT] into [Ident], do something like:
Definition Ident'' : IdentT.
  simpl_definition_by_exact Ident'.
Defined.
(* Then we clean up a bit with reduction. *)
Definition Ident := Eval cbv beta iota zeta delta [Ident''] in Ident''.
I have two questions:
(1) Is there a way to automate the last two steps, either by macros or Ltac or whatever, so that I can run something like
Simpl Definition Ident := Ident'.
or
Definition Ident := Eval simpl_definition in Ident'
and have it expand this to what's commented out above?
(2) Is there a way to simplify types?  That is, say I have a type [fooT], and I've defined [foo] to be
[Definition foo : fooT := ...]
is there a way to define [foo' := foo] so that [pose foo' as H] is the same as [pose foo as H; unfold fooT in H]?
I've tried
Definition fooT' := nat.
Definition fooT := fooT'.
Parameter bar : fooT.
Definition bar' := bar.
Definition foo := bar'.
Definition foo' := Eval compute in foo.
Definition foo'' := Eval cbv beta iota zeta delta [foo fooT] in foo.
Print foo'.
Print foo''.
but neither works when [bar] is opaque.  (Yes, I realize that I can do [Check foo], copy/paste the output to run [Eval simpl in _], and then copy/paste the output of that to [Definition foo' : _ := foo] (where I fill in the underscore by hand.)  I'm looking for a way to do this in an automated fashion.
The closest I've come is
Section typeof.
  Let typeof (A : Type) (a : A) := A.
  Let foo''T := Eval simpl in typeof foo''.
  Let foo''T' := Eval cbv beta iota delta [typeof foo''T fooT] zeta in foo''T.
  Definition foo''' : foo''T' := Eval unfold foo'' in foo''.
End typeof.
Print foo'''.
but this leaves an extra [let foo''T' := fooT' in ] that it would be nice to remove.
Thanks.
-Jason
  • [Coq-Club] Automated Simplification of Definitions, Jason Gross, 07/02/2012
