- To: coq-club AT inria.fr
- Subject: [Coq-Club] Variant of [etransitivity] that accepts arguments?
- Date: Wed, 4 Jul 2012 16:01:52 -0400
Is there a variant of [etransitivity] that accepts an argument, so that I can help Coq along in figuring out how to do transitivity? That is, is there a tactic that I can pass along an _expression_ [expr], which has some underscores in it, and which will do something like
match goal with
| [ |- @eq ?A ?a ?b ] => eapply (@eq_trans A a foo b)
end.
except that it will work with any parametric relation declared to be transitive?
If I try [etransitivity foo], I get
Toplevel input, characters 35-36:
Syntax error: '.' or '...' expected after [tactic:tactic] (in [proof_mode:subgoal_command]).
Thanks!
-Jason
- [Coq-Club] Variant of [etransitivity] that accepts arguments?, Jason Gross, 07/04/2012
- Message not available
- Re: [Coq-Club] Variant of [etransitivity] that accepts arguments?, Jason Gross, 07/04/2012
