- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Typeclasses and hints?
- Date: Fri, 6 Jul 2012 17:43:46 -0400 (EDT)
I am turning the finite map library into a typeclass and extending it to use
setoids. There are different properties about them that are registered as
immediate or for resolve, but I can't do that kind of hint registration with
typeclass members. For example:
Class TC := { mem : forall x : Type, x = x}.
Hint Immediate mem.
Error: Cannot infer the implicit parameter TC of mem.
Could not find an instance for "TC".
This seems like the wrong semantics for hint registration (trying to infer an
instance at the definition site). Am I misguided in this? Also, it turns out
that since the environment was so large at this hint definition, the
inference just went out to lunch. I had to guess that this was the problem.
I also learned that I reaaaaally want a "Section"-like typeclass definition
form. I ended up having to write a section that defined all the types I
wanted for the class along with the auxiliary definitions, then defining the
typeclass with all the quantifiers... blech.
Thanks,
-J. Ian Johnson
- [Coq-Club] Typeclasses and hints?, J. Ian Johnson, 07/06/2012
- Re: [Coq-Club] Typeclasses and hints?, Adam Chlipala, 07/06/2012
- <Possible follow-up(s)>
- Re: [Coq-Club] Typeclasses and hints?, J. Ian Johnson, 07/07/2012
