- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tuning opaqueness
- Date: Sun, 08 Jul 2012 12:20:52 +0200
Am 08.07.2012 01:20, schrieb Jason Gross:
Hi,
Is there a way to make a constant opaque or transparent within a tactic? Relatedly, is there a way to state that a constant should usually be opaque, unless its first few arguments match a specific pattern?
The context is that I've moved some [Record] fields to parameters, so that I get sort-polymorphism, but I want to pretend that these things are record fields, so that I can build tactics that match on them and so that the "fields that are really parameters" carry along the information of what record they come from. So I generally want these things to be opaque, so that [simpl] and [hnf] don't unfold them, but I sometimes need to see inside them. (Currently, there seems to be a theorem that I can only [eapply] if I make these transparent.) So I either want to tune how opaque these constants are, and/or I want to be able to flip opaqueness back and forth inside of tactics.
Thanks!
-Jason
No, but I'm sure that you can Hack arround it by having a second definition that you prove to be equal to the first one, then you make the second one opaque.
Definition plusopaque x y := x + y.
Lemma pluseq : forall x y, plusopaque x y = x + y.
reflexivity. Qed.
Opaque plusopaque.
- [Coq-Club] Tuning opaqueness, Jason Gross, 07/08/2012
- Re: [Coq-Club] Tuning opaqueness, Jonas Oberhauser, 07/08/2012
- Re: [Coq-Club] Tuning opaqueness, Gregory Malecha, 07/08/2012
- Re: [Coq-Club] Tuning opaqueness, AUGER Cédric, 07/09/2012
- Re: [Coq-Club] Tuning opaqueness, Jason Gross, 07/09/2012
