- To: Alexander Katovsky <apk32 AT cam.ac.uk>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proving equality of records
- Date: Tue, 17 Jul 2012 16:30:07 -0400
Which version of Coq are you using? In 8.4beta2, [f_equal] finishes the proof for you. Alternatively, in 8.4beta2, you can do [change (fun x y : Obj => Hom x y) with Hom], though I don't think 8.3 implements eta conversion.
In 8.3.... I'm not sure if there's a good way to do it. You could prove [(fun x y : Obj => Hom x y) = Hom] by [functional_extensionality_dep] (from [FunctionalExtensionality]), and then use [JMeq_eq] (in [JMeq]) to say that you can prove [JMeq
C Op(Op(C))] instead of [eq
C Op(Op(C))], and then you can rewrite on one side of the equation at a time.
Another way to do it is to do something like
Require Import JMeq.
Local Infix "~=" := JMeq (at level 70).
Definition Obj (C : Cat) := match C with MkCat Obj _ _ => Obj end.
Definition HomT (C : Cat) : { A : Type & A }.
destruct C.
exact (existT _ _ Hom).
Defined.
Definition Hom C : projT1 (HomT C) := projT2 (HomT C).
Definition IdT (C : Cat) : { A : Type & A }.
destruct C.
exact (existT _ _ Id).
Defined.
Definition Id C : projT1 (IdT C) := projT2 (IdT C).
Lemma cat_eq (C C' : Cat) : Obj C = Obj C' -> Hom C ~= Hom C' -> Id C ~= Id C' -> C = C'.
destruct C, C'.
intros; simpl in *; repeat subst.
unfold Hom, Id, HomT, IdT in *.
simpl in *.
repeat subst.
reflexivity.
Qed.
and then [apply cat_eq]. Although if you're going to do that, you might want to use a [Record], like
Record Cat := {
Obj : Type;
Hom : Obj -> Obj -> Set;
Id : forall x : Obj, Hom x x
which defined [Obj] and [Hom] and [Id] for you.
-Jason
On Tue, Jul 17, 2012 at 4:02 PM, Alexander Katovsky <apk32 AT cam.ac.uk> wrote:
Inductive Cat : Type :=
MkCat : forall (Obj : Type)
(Hom : (Obj -> Obj -> Set))
(Id : forall x : Obj, Hom x x), Cat.
Definition Op (x : Cat) : Cat :=
match x with
MkCat Obj Hom Id => (MkCat Obj (fun x y => Hom y x) Id)
end.
Lemma OpOp: forall C, C = Op(Op(C)).
unfold Op.
intro C.
case C; simpl.
intros Obj Hom Id.
f_equal.
intros H_Obj H_Hom H_Id.
dependent rewrite <- H_Hom.
- [Coq-Club] proving equality of records, Alexander Katovsky, 07/17/2012
- Re: [Coq-Club] proving equality of records, Jason Gross, 07/17/2012
- Re: [Coq-Club] proving equality of records, AUGER Cédric, 07/17/2012
