- To: coq-club AT inria.fr
- Subject: [Coq-Club] Building coq on windows
- Date: Fri, 20 Jul 2012 15:06:31 -0400
Hi,
I'm trying to build Coq on windows, and make gives me the following error (full logs at https://www.dropbox.com/s/uz32nelthtu1r22/configure.txt and https://www.dropbox.com/s/163v4c33xwe5796/make.txt)
OCAMLC kernel/byterun/coq_fix_code.c
gcc: The -mno-cygwin flag has been removed; use a mingw-targeted cross-compiler.
Makefile.build:823: recipe for target `kernel/byterun/coq_fix_code.o' failed
make[1]: *** [kernel/byterun/coq_fix_code.o] Error 2
make[1]: Leaving directory `/cygdrive/d/Documents/Dropbox/MIT/2012 Summer/Categorical Informatics UROP/coq'
Makefile:139: recipe for target `world' failed
make: *** [world] Error 2
Does this mean that I'm supposed to pass an argument to ./configure to tell cygwin to target mingw (what argument?), or that I'm supposed to use mingw instead of cygwin (but OCaml says at http://protz.github.com/ocaml-installer/ that MSys/MinGW is no longer supported), or something else?
Thanks in advance for any help.
-Jason
- [Coq-Club] Building coq on windows, Jason Gross, 07/20/2012
