[Coq-Club] Recursive tactic notations, or converting from gallina numbers to ltac integers
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Recursive tactic notations, or converting from gallina numbers to ltac integers
- Date: Fri, 20 Jul 2012 22:11:42 -0400
Hi,
I'm trying to construct a tactic that rewrites with a lemma [nat_assoc] repeatedly, and tries to solve the resulting goal after each rewrite. (That is, I'm trying to create a tactic that tries to solve the goal with a particular tactic in every possible permutation of parenthetizations).
Lemma nat_assoc a b c : (a + b) + c = a + (b + c).
induction a; simpl; try reflexivity.
rewrite IHa; reflexivity.
Qed.
However, it seems that [Tactic Notation]s can't be recursive, and I can't figure out a way to [rewrite nat_assoc at n] if [n] is passed into a standard tactic; none of the following work:
Goal forall (a b c d e f g : nat), a + b + c + d + e + f = g.
Ltac stepAssociativity' n := rewrite nat_assoc at n.
(* stepAssociativity' 1. *) (* In nested Ltac calls to "stepAssociativity'" and
"rewrite nat_assoc in |- * at n", last call failed.
Error: Ltac variable n is bound to a term which cannot be coerced to
an integer. *)
(* Tactic Notation "stepAssociativity" integer(n) :=
rewrite nat_assoc at n; try stepAssociativity (S n). *) (* Error: The reference stepAssociativity was not found in the current
environment.*)
Does anyone have ideas/suggestions?
Thanks.
-Jason
- [Coq-Club] Recursive tactic notations, or converting from gallina numbers to ltac integers, Jason Gross, 07/21/2012
