coq-club - Re: [Coq-Club] Unifying proof goals
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unifying proof goals
  • Date: Thu, 2 Aug 2012 03:45:23 +0200
Le Wed, 1 Aug 2012 20:15:45 -0400,
Jason Gross
a écrit :
> Hi,
> If I have two proof goals that are identical, is there a way to tell
> Coq "get rid of one of the proof goals because it's the same as this
> one"? Or something (a variant of [abstract], maybe?) that says
> "solve these both using this tactic, but only run the tactic once,
> because it's expensive"?
> Thanks.
> -Jason
I guess it is not what you want, but you still can use
cut/assert/pose/set tactics. You can even use a "refine (let H :
<your proof> := _ in _)." or variants if you want to be at a very low
level.
Of course that needs to identify the goals you will need to unify
before trying to solve them.
